Author Topic: Horn Relay or Fuse?  (Read 45299 times)
Offline pedigo78
  • Big Blue
Horn Relay or Fuse?
« on: July 06, 2011, 07:42:11 pm »
I have an 85 k20 that is missing a horn. I am missing the hole assembly in the steering wheel but I was also wondering if there is a relay or fuse? If there is where is it located? Also I am wondering how do you remove the actual dash pad. I am going to install a radio but I need to take a look at the speakers
Sgt Pedigo USMC
Offline bigchevyc30
  • the pig
Re: Horn Relay or Fuse?
« Reply #1 on: July 06, 2011, 08:08:22 pm »
well i have the same issue for the horn but i just bought a switch and hooked up the horn to power. for the dash pad on the pasenger side is about 4 screws if i remeber right and the screws on the driver side that hold the cover for the gauges that hold it down and it then comes out. hope this helps you some
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline pedigo78
  • Big Blue
« Reply #2 on: July 07, 2011, 07:27:43 am »
Thanks
Sgt Pedigo USMC
« Reply #3 on: July 21, 2011, 04:19:55 pm »
The horn has a contact under the wheel.
The dash comes off by removing all the bolts in the instrument bezel and the 4 bolts across the bottom of the passenger side dash and on 81-87 dashes there is a bolt in the end of the dash.
Offline junkman.
« Reply #4 on: July 31, 2011, 02:08:59 pm »
hello i have a 82 1500 the horn rely is hanging  on top of the fuse block the first thing i would check is the horn itself and hook up a test light to the horn wire if it lights up everything should be good
if the horn contact is bad or disconnected you won't here the relay note there,s other things that could be wrong  hope this helps   JM
Offline pedigo78
  • Big Blue
« Reply #5 on: July 31, 2011, 05:48:57 pm »
Do you think you could take a pic and show me which one the horn relay is? I am in the process of locating the button and contacts that go into the steering wheel column. I am going to have to buy that stuff from  .
Sgt Pedigo USMC
Offline junkman.
« Reply #6 on: August 01, 2011, 12:45:23 am »
Here's some pics its hard to find there's two levers you lift away from the relay
its hanging from the harness its not in the fuse block
Offline pedigo78
  • Big Blue
« Reply #7 on: August 01, 2011, 09:51:34 am »
Ok thanks
Sgt Pedigo USMC
Offline pedigo78
  • Big Blue
« Reply #8 on: August 01, 2011, 07:07:52 pm »
Yeah I must not have one, or there is a difference between an 82 and 85, or I am just blind or dumb. cause i cant find it.
Sgt Pedigo USMC
Offline 1979C20
  • Kyle Taulton.
« Reply #9 on: August 01, 2011, 07:09:55 pm »
Maybe its missing? Look for the plug where it belongs and.bb if you find the plug then you need the relay.
Offline pedigo78
  • Big Blue
« Reply #10 on: August 01, 2011, 07:29:49 pm »
SO while I was under there i noticed a single brown wire with a white stripe under the dash with a single connector on it but it wasnt connected to anything. It was near the fuse block kinda. I looked on a wiring diagram on here and it says that it Goes to the  (To Bulkhead Gen Res) 25. Any clue what that means. That and the stupid horn relay
Sgt Pedigo USMC
Offline junkman.
« Reply #11 on: August 02, 2011, 01:25:57 am »
OK lets see have you found and checked the fuse (its good) next did you check the horn itself (its good)
I think the relay works like this four wires go to it two comes from the fuse (they are crimped together)
one from the horn button and one goes to the horn.
on the 82 fuse wires are orange the horn contact wire is black and the one for the horn is green.
there is a buzzer plugged in at the top of my fuse block next to the top silver flasher unit my horn relay is on top of all that  try a search for horn relay or Google 85 Chevy K20 horn relay location
 hey man good luck  JM
