Author Topic: auto to 4-speed  (Read 10681 times)
Offline 1980c10
Re: auto to 4-speed
« Reply #15 on: July 10, 2011, 10:15:56 pm »
I also prefer a mechanical linkage as well, however it may be easier to set up a hydraulic linkage if you run in to problems.
Re: auto to 4-speed
« Reply #16 on: July 11, 2011, 05:36:15 am »
The nuts that hold the brake booster / pedal assembly will probably be SAE on the 79, and metric on your truck. Just an FYI.
Offline scottsdale92
Re: auto to 4-speed
« Reply #17 on: July 14, 2011, 06:58:15 am »
do i also have to switch my booster and master cylinder,and im gonna use a hydraulic clutch in for the ease of installation,could i use the z-bar pedal for my hyd. clutch?,this forum is really big help with projects by the way
1984 chevy scottsdale LB 4x4
Offline 1980c10
Re: auto to 4-speed
« Reply #18 on: July 15, 2011, 12:08:43 am »
You don't need to switch the brake booster and master; however, if you switch one you'll need to switch the other. They are interchangable to the firewall. I prefer the newer style myself and updated mine when I converted my clutch to hydraulic.
I'm not sure what you are refering to as the "z-bar pedal" If what you mean is that you're trying to make a short cut by not changing your pedal assembly; the clutch master can be installed in the same position in the firewall and bolted to the non-hydro pedal assembly if you drill a hole and use a pin in the clutch pedal arm but would be more straight foward to get the correct pedal assembly.
anyway I have some photos in my project thread of the both versions of pedal assemblies and some other info as far as placement of the clutch master etc. just read through I think somewhere in the middle you'll find the clutch info.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=12330.0
Re: auto to 4-speed
« Reply #19 on: July 15, 2011, 05:47:49 am »
I put a standard shift juice clutch cab on a mechanical chassis one time years ago and used the juice clutch pedal. I had to modify it though. I don't recall exactly what I did to it, but I do remember laying upside down under the dash welding something!
Offline 1980c10
Re: auto to 4-speed
« Reply #20 on: July 15, 2011, 05:20:16 pm »
The pedal on the hyrdraulic version is a little longer to help with leverage.
