Author Topic: auto to 4-speed  (Read 10680 times)
Offline scottsdale92
auto to 4-speed
« on: July 08, 2011, 08:03:38 pm »
im switching my 700r4 scottsdale longbed 4x4 to 4 speed,need info on what trans and drive shatfs to use
1984 chevy scottsdale LB 4x4
Offline 1979C20
  • Kyle Taulton.
Re: auto to 4-speed
« Reply #1 on: July 08, 2011, 08:40:09 pm »
Youll need sm465 tranny but it has tp be 4x4 verison. Youll need bell crank, clutch and brake pedal assemblies, fly wheel, clutch disk assembly, front and rear drive shafts, transfer case. Your best bet would be to find either a parts truck thats 4x4 4 speed to get your parts off of it, or use that truck and put your engine in it.
Re: auto to 4-speed
« Reply #2 on: July 08, 2011, 11:56:54 pm »
why do you want to switch? also to add on you need the whole clutch assembly from the pedal inside the cab to the fork brackets also
Offline 1979C20
  • Kyle Taulton.
Re: auto to 4-speed
« Reply #3 on: July 09, 2011, 12:10:34 am »
I listed that, Irish. The bell crank is the pivot rod that goes between the bell housing and the frame, and the rod that moves the bell crank I think is part of the pedal assembly. And, I personally would rather have a manual off road. More control over power and what not but, im not sure why he wants the swap.
Re: auto to 4-speed
« Reply #4 on: July 09, 2011, 12:21:21 am »
lmao i dont know how i skipped that sorry bud
Offline 1979C20
  • Kyle Taulton.
Re: auto to 4-speed
« Reply #5 on: July 09, 2011, 12:51:27 am »
Ah, no worries. Oh, and the tranny crossmember may need to be moved since the SM465 is short. And you might want a new steering collumn without the shifter for the auto. And you will have to have a high hump tranny tunnel and will have to cut a hole out of it, or replace it with one from a manual truck.
Re: auto to 4-speed
« Reply #6 on: July 09, 2011, 07:05:49 am »
well im not big in automatics and i wanna lift it,i have a buddy with a rusted out 79 blazer thats 4 speed,would the parts out of it as far as trans and pedal assembly be compatible with my pickup?
Offline 1979C20
  • Kyle Taulton.
Re: auto to 4-speed
« Reply #7 on: July 09, 2011, 07:51:37 am »
Yes, drive shafts will be different lengths though, so youll need drive shafts.
Re: auto to 4-speed
« Reply #8 on: July 09, 2011, 08:22:59 am »
just a new rear shaft or you might get lucky and your old might fit or close enough to get cut down
Re: auto to 4-speed
« Reply #9 on: July 09, 2011, 08:37:57 am »
thanks guys,you ever done a swap like this?
Re: auto to 4-speed
« Reply #10 on: July 09, 2011, 09:25:12 am »
its not ihard at all if you can pull the trans then your all good
Offline 1980c10
Re: auto to 4-speed
« Reply #11 on: July 10, 2011, 09:24:50 am »
Be aware that if you can find parts from an 85+ it will have a hydrualic clutch linkage. I've done somewhat similar swaps; just be sure you have the right parts and go in with a plan and you will be surprised at how easy and fast it goes. btw to hang a new pedal assembly you will need to remove the steering column so this would be a good time to get one for a m/t truck.
Re: auto to 4-speed
« Reply #12 on: July 10, 2011, 11:44:56 am »
alright thanks,im using a 79' gmc jimmy for for the trans,t-case,and pedal assemblies.it does have a z-bar or mechanical clutch.which one is better to use?
Offline 1979C20
  • Kyle Taulton.
Re: auto to 4-speed
« Reply #13 on: July 10, 2011, 05:46:55 pm »
I prefer mechanical, but its all preference.
Re: auto to 4-speed
« Reply #14 on: July 10, 2011, 08:17:40 pm »
x2
