Author Topic: upper steering column bearing  (Read 7240 times)
Offline Flamingbig10
« on: July 12, 2011, 10:17:04 pm »
I put a new turn signal switch in my 84 auto, tilt column, after I pulled the old switch old I cleaned up and painted the column.  When I picked up the column I heard something hit the ground so look down and it was a race, so stuck it back in and reinstalled the column parts when I got the part to install the lock plate the shaft became really loose I believe is  there supposed to be a retainer to hold the race in.  I did look at this thread but it didn't help me completely
http://forum.73-87chevytrucks.com/smforum/index.php?topic=12525.0[/QUOTE]
Re: upper steering column bearing
« Reply #1 on: July 14, 2011, 11:57:08 am »
I haven't torn one down that far are you talking about the end of the column?
There should be something holding it in.
« Reply #2 on: July 16, 2011, 03:06:06 pm »
I figured out what I lost it was the upper bearing race cup, I ordered a new on  through gm and got it back together
