Author Topic: brake lites  (Read 5114 times)
Offline jt1200r
brake lites
« on: July 16, 2011, 01:15:46 pm »
my rear brake,signal and hazard lites dont work. the running and backup lites work. the front and dash signal lites work. any ideas what it could be ? its a 87 r10 step side .Thanks
87 R10 4.3
Offline 1979C20
  • Kyle Taulton.
Re: brake lites
« Reply #1 on: July 16, 2011, 01:41:03 pm »
Wiring under the bumper, and its "lights".
Offline jt1200r
Re: brake lites
« Reply #2 on: July 16, 2011, 03:43:56 pm »
i dont have a rear bumper. my tag lites dont work either
87 R10 4.3
Offline 1979C20
  • Kyle Taulton.
Re: brake lites
« Reply #3 on: July 16, 2011, 05:24:33 pm »
Under where the bumper bolts to the frame. Like, under the bed at the very end of the truck.
Offline 1979C20
  • Kyle Taulton.
Re: brake lites
« Reply #4 on: July 16, 2011, 05:25:14 pm »
Also, check brake light fuse.
Offline jt1200r
Re: brake lites
« Reply #5 on: July 16, 2011, 08:33:09 pm »
fuse is good. i checked the ground thats about the center of the bed in the rear
87 R10 4.3
Offline 1979C20
  • Kyle Taulton.
Re: brake lites
« Reply #6 on: July 16, 2011, 10:28:10 pm »
Check the whole wiring harness under it.
Re: brake lites
« Reply #7 on: July 17, 2011, 12:01:59 am »
like 79 was saying there should be a junction where the bumper used to be where the wires are split up. sometimes p.o. will mess with them and sometime later it will just fail
Offline jt1200r
Re: brake lites
« Reply #8 on: July 17, 2011, 07:42:33 am »
ill be checking that today
87 R10 4.3
Offline jt1200r
Re: brake lites
« Reply #9 on: July 17, 2011, 10:07:19 am »
got them working. the little tits on one bulb werent contacting and the connecter on the other side went bad. crazy that 2 different things go bad at the same time. thanks for all the suggestions
87 R10 4.3
Re: brake lites
« Reply #10 on: July 17, 2011, 10:46:44 am »
The turn signal and brake lights are the same filament
