Author Topic: swap 250/350  (Read 3171 times)
Offline mrnda
swap 250/350
« on: July 17, 2011, 01:20:48 pm »
Gonna get an 83ish truck with an inline engine and swap it with a 350.  my concern is the exhaust system.  I imagine i will have to transplant everything from the doner truck to the new one.  Doner truck is same year but automatic trans, new truck is manual trans.  I will also have to change the flywheel to i believe, would the one from the inline engine be usable on the 350???????????????
Thank for any input.
Offline 1980c10
Re: swap 250/350
« Reply #1 on: July 17, 2011, 03:21:02 pm »
You can swap the flywheel they would be the same. Accelorator cable is shorter with a 350 as well so swap them. you'll have to move the motor mounts to the other set of holes. Also install a pilot bushing in the back of the crank.
Offline mrnda
Re: swap 250/350
« Reply #2 on: July 18, 2011, 11:40:11 am »
Throttle cable and pilot bushing thanks, definantly wouldnt have come to mind.
Re: swap 250/350
« Reply #3 on: July 21, 2011, 03:23:21 pm »
radiator, fan and shroud would best to be updated also.
