Author Topic: cant keep balanced  (Read 9143 times)
Offline Sierra4x4
cant keep balanced
« on: April 15, 2003, 12:42:00 am »
having problems keeping my tires balanced. The wieghts keep comming off. Shakes me to death at 30-40. Can i use some super glue? im serious! its like the lip of my rim isnt very good at holding them on. And if anything thinks im just making a mountain out of a mole hill, I thought the drivers door was gonna come off, my foot would hardly stay on the gas pedal, and i thought my dash was going to come apart. How can i keep the weights on!?
Offline Kevin108
Re: cant keep balanced
« Reply #1 on: April 15, 2003, 06:13:00 am »
I hate to say it...but it's based on your tire choice and everybody's just gonna say, "I told you so!"  :lol
Super glue wouldn't hold up to the heat and the elements.  You'd need like marine epoxy or something.
87 Silverado ½-ton 4x4 Longbed Pickup
350 TBI, 700R4 w/ Corvette servo
4" Skyjacker, 33x12.50s
14-bolt rear & Detroit coming soon
My Mods | Truck Pics | Kevin108@PavementSucks.com
Offline Sierra4x4
« Reply #2 on: April 15, 2003, 08:02:00 am »
hhhmmm well by the looks of it, its not the tire. its the rim. he said it had a funny lip on it, and nothing would really 'stick'. noone said anything about the tire itself being at fault. They thought that was the problem at first, but once they got looking at it closer, one tire actually had no weights on it, its just the rear tires as well. Not so much the front. they also said the first shop had only done a static balance instead of a dynamic balance. I think this would have happened with any 35x12.50x15... Im gonna drop it back off and see if they can do anything for it. luckily its across the street ;)
Offline Sierra4x4
« Reply #3 on: April 15, 2003, 10:23:00 am »
got it fixed rides great, but check out my axle post in the 73-87 trucks section....:x
Offline Kevin108
« Reply #4 on: April 15, 2003, 04:49:00 pm »
My point is some 35s never need any weights...and some 35s never balance.  :-)  Never know what you're gonna get though.
Offline abig84
balancing
« Reply #5 on: May 06, 2003, 06:18:00 pm »
i got 38s and them thing would shake so bad between 25-35mph  thought it was gonna fall apart and they were so unbalanced that a tire place couldnt balance them, what i did is had the tire place tell me how much weight do i need and where on the rim does it have to be placed and took a thick piece of wire and put it between the holes on the rim in the location of where it needed to be and 2 huge bolts that weighed what i needed and twisted it to hold the bolts on, it looks like crap but it did the job
Offline Sierra4x4
Re: balancing
« Reply #6 on: May 10, 2003, 08:34:00 am »
i think alot of my problems were the darn flat spots. i need more air in the tires. seems i only have around 25, what should i be running? i think it said max 30 psi... since i may be getting a car to daily drive (hey its FREE) my next tires could be boggers if i can live with the vibes. if not im getting some wrangler mt/r's.
Offline 79GMC4x4
Radials are the way to go
« Reply #7 on: June 25, 2003, 01:08:00 am »
Stay away from bias ply if you hate the flat spot before warm up.  If you want to spend the money, some shops will balance big tires with a powder balancer.  For 36 bucks, I said I will just bounce around.;)
