Author Topic: 350/th350 to 454/th400 swap  (Read 5401 times)
Offline schulerboy
« on: July 18, 2011, 11:45:01 pm »
Hello, I am seeking some advice regarding swapping the 350/th350 to a 454/th400. My truck is a 75 gmc 1/2ton 2 wheel drive with a 1 piece driveshaft and the doner is a74 3/4ton 2 wheel drive with a 2 piece driveshaft. The tranny mounts look a little different but my main concern is what to do with the driveshaft. What is easier and the best way to go?
Offline bigchevyc30
  • the pig
Re: 350/th350 to 454/th400 swap
« Reply #1 on: July 19, 2011, 12:03:45 am »
really you wouldnt know due to we dont know the classification of the trucks are they 4door, 2door, short bed, standard bed, or long bed. i know i couldnt help with the final answer but this will help others that do know
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
« Reply #2 on: July 19, 2011, 12:44:58 am »
if they are both the same length as stated take the cross member out of the 3/4 and put it in yours and then use the driveshaft. if not the same length get your 1 piece cut down or the 2 piece cut down. its cheaper and easier to cut one down then to lengthen it
Offline schulerboy
« Reply #3 on: July 19, 2011, 07:07:01 pm »
Both trucks are regular cab long boxes. One concern I have in using the two piece shaft is the center carrier bearing. The bracket it mounts to on the 3/4 ton I don't think I can swap into the 1/2 ton. Would it be easier to just fabricate a new mount for it or is there another bolt in bracket from another year?
« Reply #4 on: July 19, 2011, 11:51:35 pm »
it should fit but if not i have used just a piece of 4" channel before and bolted it to the cross member
Offline Senck243
« Reply #5 on: July 20, 2011, 09:17:21 am »
Go to your local driveline shop and get a price on a custom shaft the are around 200-300$.
1984 k10 305, sm465, np208
« Reply #6 on: July 20, 2011, 09:33:46 am »
yeah only a couple bucks lol. but you can rig one up and work fine. i know i measured a 1/2ton frame and a 3/4 ton both where the same. can this be said for all no but i know the two i measured where the same
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #7 on: July 20, 2011, 09:44:03 am »
You could go to a drive line shop and have your 1 piece shortened and balanced for around $100.00
