Author Topic: How much fabric needed?  (Read 10624 times)
Offline thachevythang
« on: July 20, 2011, 07:22:32 am »
I plan on covering my dash pad, door panels (including the arm pads & trim for the door pull), headliner, kick panels, ac trim, and all interior pillars with fabric. Pretty much all the plastic besides the gauge area. Has anybody done this or know about how many yards I need? Maybe direct me to a how to on covering or upholstery? Don't want my cab smelling like a paint can. I did the dash and pillars back in Feb. and it still smells.
« Last Edit: July 20, 2011, 07:34:40 am by thachevythang »
'85 SHORTBED
Re: How much fabric needed?
« Reply #1 on: July 21, 2011, 02:36:27 am »
Nobody? Most places I found with fabric for sale online have either a 36" or 53" wide by how many ever yards needed. I guess just measure the door panels, the dash length, headliner, and then get about 3 or 4 yards. Should be enough but I see the headliner giving me problems. Its in perfect condition, I just don't want it blue.
Anybody reccomend a certain spray adhesive? Tips on how to? Maybe a fabric dye for the headliner?
I remember seeing a post where someone was adding fabric and painting their trim in a blazer. The interior was red, had some hawaiian seat covers. I think did a console with carpet in it as well. Searched for it but couldn't find that post. I remember it had some info along the lines of what I'm trying to do. Anybody know the post?
'85 SHORTBED
« Reply #2 on: July 21, 2011, 02:32:01 pm »
To recover the interior you need to lay everything out and measure each piece to get an idea on how much you plan to cover and assume some overages if you are going to do panels and wrap them over.
What kind of paint did you use on the pillars?   I painted all the plastic in a truck once and it never smelled.
« Reply #3 on: July 22, 2011, 02:53:53 am »
I used the krylon fusion, satin black. Its been some time but still has the smell. I wouldn't say overpowering, but after sitting a day or two without the windows down, its there.
I resorted to google and youtube to see what I could find. Since there's not much here on a how to I'll do my best for anybody in the future. Here's some info and techniques: Youtube search (how to wrap interior, how to wrap with vinyl, you'll get most of the same vids)
Most post are people using vinyl, (full vinyl not backed by any material, I can only find polyester backed in materials I like)
a bonding agent,
and a heat gun.
Even the most complex shapes and curves get covered fairly easy. Round gauges, dash curves, etc.
Clean the surface with a degreaser,
apply bonding agent (some use cement compound, not sure if its the best but at least 3 post had used it),
mock your vinyl in the position or direction of pattern desired,
apply heat with the heat gun, and use a window tint squeegee or like device, to remove the air pockets if any. Stretching the vinyl helps avoid the air pockets and get around curves.
contour the vinyl to the shape of the surface, again stretching while applying heat. Avoid overheating by doing a section at a time. Slow is smooth, smooth is fast! If you don't like the section you have time to apply heat, pull the vinyl back and restart from that point at least.
tuck in tight in all creases, edges, use hands, tools, whatever fits the lines of the vehicle.
then cut excess with a razor or exacto knife along creases and edges.
With vinyl prints you can do anything from carbon fiber, woodgrain, glossy, etc. Would be a good alternative to those that might want that shiny fiberglass look without that extra labor. Just an idea???
The best vid I found: http://www.youtube.com/watch?v=fhj3yAbEbAw
For steering wheels, pretty much the best one, heres the link: http://www.youtube.com/watch?v=fJEm7SKbFWE
Theres a user on there that goes into detail on how to fully cover the wheel but the vid is covered by instructions in yellow and hard to see the work at times.
Headliners are done with various materials. Remove the old material and foam, get down to the bare board or plastic, measure your piece, cut with some over length, apply a spray adhesive glue to one half, use the same method to remove air pockets, do the other half, and finish. Most headliners don't have too many lines so seems easy. Best how to here:
http://www.youtube.com/watch?v=oDCH5zEu5-k
Door panels and trim can be done in either of the above methods. You have to do more cutting to get around curves and whatnot for the glue method but heres a decent vid: http://www.youtube.com/watch?v=9dckYX1jKvs
I'm not saying these are THE WAY to do it, but A WAY to get it done with decent results. Since not much on this topic I figured I could give back, share my research, and at least give some insight to easier projects. I'll be starting my project after I find and order decent material. I'm going to try both methods to see what works best for me and if one method is easier on certain parts. Thanks for reading!
'85 SHORTBED
Offline reload
    • K & K Innovations
« Reply #4 on: July 22, 2011, 07:41:10 pm »
Just wanted to say thanks for doing some of the leg work, and still posting your findings, most would have just ignored the thread and went on with there business.
That said you found some great info!   ;D
Offline Dr_Snooz
« Reply #5 on: July 22, 2011, 08:59:41 pm »
Excellent post! I look forward to seeing your results.
« Reply #6 on: July 25, 2011, 05:59:55 am »
NO PROBLEM! Just glad to share some. Found some materials I like. I couldn't find full vinyl prints I wanted under 30 bucks a yard. I found the same prints backed with polyester that have vertical stretch for about 8 dollars a yard! So I will be using the glue method.
Might bite the bullet for the dash though! I don't want it looking like junk. Thinking about stripping it all the way down to the metal. Cover in foam and wrap it. It's cracked pretty good. I did the project with the sanding and filler foam. Its even up top and on the dash face but the rear near the window couldn't be saved. I'll work it out though.
I should be in transition to a new job soon so after a little time I'll get on it. I'll do an in depth write up in the projects when comes time. It's going to be a snakeskin wrap on the dash, some sued and a little bit of rattlesnake.
Long story short, went to work on the truck. Right when I went to go underneath heard the rattle. Not unusual where I live. West TX. I don't fear them or wanna kill 'em all. I just sprayed him away with my pressure washer and continued to work. I don't mess with them, they don't mess with me, but sometimes were both in a bad position and they aren't so lucky. This one just gave me a theme for the truck so he got to slither away.
'85 SHORTBED
« Reply #7 on: July 27, 2011, 05:31:07 am »
Here's my order. The sued looks too shiny but I'll see when I get the order. The snakeskin is embossed and the sued has a backing so I'm safe for gluing. I found a vid on youtube with an ostrich wrap interior on an 86. It wasn't the best of job but you could tell it was rushed. I'm a perfectionist so I'll be doing lots of practice!!! Also moving to another JOB so it might be a good while before I post results. The rattlesnake skin is still a search until I know exactly what I'm going to do with it. Maybe wrap my steering wheel? Who knows but it's going in there. Here are the samples.
'85 SHORTBED
