Author Topic: NON 73-87 BRAKE ISSUES  (Read 5780 times)
Offline 73SWBBB
  • constant problems
« on: July 25, 2011, 04:14:45 pm »
Im hoping I can get a little help on this forum without joining another. I have an 05 sierra crew sle with less than 10K on the new rear brakes. Recently they have seemed to almost lock up after coming to a complete stop. The squeak and drag the more I drive it. Sometimes it has no issues at all. With out having inspected it yet, anyone have any pointers for when I rip into this thing? I pulled it apart about 1000 miles ago and cleaned everything up and it went away but it soon came back.
Offline 1979C20
  • Kyle Taulton.
Re: NON 73-87 BRAKE ISSUES
« Reply #1 on: July 25, 2011, 05:35:32 pm »
Some people on the forum said that if the rubber brake line is getting dry and cracked it can act like a check valve not release the brakes. They aay one way to test it is crack the bleeder valve and if it releases the brakes than you need a new brake line.
« Reply #2 on: July 25, 2011, 06:09:14 pm »
Did you have the drums machined?  Did you get quality brake shoes?  The smaller shoe towards the front?  I got no idea if they are disc brakes in back though... I'll sit back and learn from the experts.
Offline 73SWBBB
  • constant problems
« Reply #3 on: July 25, 2011, 06:19:14 pm »
they were machined with decent quality pads and properly installed. like I said everything was good for about 10K but recently it seems something has happend back there, they are drums. I will pull the drums when I get home. Just wanted to see if anyone else has had any similar issues. Its all i am thinking about right now and i should be working. ha
