Author Topic: 700r4 original wiring diagram  (Read 30822 times)
Offline williebm3
« on: July 28, 2011, 08:59:18 am »
I am looking for an original schematic of an 83 1/2 ton 2wd of the 700r4 wiring. PO cut wiring at firewall and it looks as if everything under dash is in tact but not for sure. Have a blue and light green wire coming out of firewall and it looks as if they were the only ones that cam out of there originally. have vacuum switch off of an 83 van and was thinking about pulling the cruise control off of it also and wondering if all of it would swap? Any input would be great. Thanks.
Offline thirsty
    • Suitor's Garage
Re: 700r4 original wiring diagram
« Reply #1 on: July 28, 2011, 12:29:15 pm »
Offline williebm3
« Reply #2 on: July 28, 2011, 02:14:35 pm »
Can't find where these all originate from on these schematics. Not very good with them anyway, but I sure can't find it.
Offline 1979C20
  • Kyle Taulton.
« Reply #3 on: July 28, 2011, 02:37:52 pm »
A picture of the wires would help a lot. Is it the 3 wires that come out of the firewall just to the right of where the throttle cable comes out? If so, I believe those are the wires for the revere lights.
Offline thirsty
    • Suitor's Garage
« Reply #4 on: July 28, 2011, 03:10:43 pm »
My reverse lights on my SM465 are blue and green.
Offline 1979C20
  • Kyle Taulton.
« Reply #5 on: July 28, 2011, 03:18:04 pm »
x2
« Reply #6 on: July 28, 2011, 06:43:02 pm »
Dual tank switch for me...
Offline williebm3
« Reply #7 on: July 29, 2011, 03:16:16 pm »
So how the heck do I wire this thing to work like the factory wanted it to? Have pulled vacuum switch from firewall of donor van, and pulled brake light switch(mine still intact under dash), and plug for tranny. Tried to follow wiring and get entire thing , but van had been hit in front and totaled so not much room. Now thinking about taking the cruise off and seeing if I can get it to work also. At a loss as to where to go from here with the tranny wiring. Any help would be great. Thanks in advance.
Offline williebm3
« Reply #8 on: August 03, 2011, 07:19:39 am »
After looking at these I can tell that you guys with the 4 speeds are correct. As the schematic says that lt green and dk blue are for the back-up light switches. But, I still cannot figure out for an auto tranny. Still stumped.
Offline williebm3
« Reply #9 on: August 03, 2011, 07:28:54 am »
Capt can you see if you can locate sheet 14? As this is where the computer control wiring system schematic says that the TCC wiring is located. Thanks if you can.
« Reply #10 on: August 03, 2011, 06:23:43 pm »
700R4's aren't computer controlled, there will be a connector going to the trans to lock up the converter and that is it.
Offline williebm3
« Reply #11 on: August 03, 2011, 10:19:02 pm »
The previous owner had cut the wiring in the endine compartment. Looks like he left the stuff under the dash intact, but not 100 percent sure. That is why I was needed a diagram for this wiring.
Offline 1979C20
  • Kyle Taulton.
« Reply #12 on: August 03, 2011, 10:27:15 pm »
Once again, a picture of the wiring will be very helpful.
Offline williebm3
« Reply #13 on: August 04, 2011, 02:06:25 pm »
I will try to get pics tonight and try to post them.
« Reply #14 on: August 04, 2011, 03:07:21 pm »
can you tell me where you are referencing the sheet 14 from.  The wiring diagrams will be in the link provided.
