Author Topic: Speedometer ?'s  (Read 16255 times)
Speedometer ?'s
« on: August 04, 2011, 03:32:34 pm »
Did GM make a mechanical speedometer that exceeds 99,999.9 miles like what is in the 1991 Suburban electronic 999,999.9?
Offline 1979C20
  • Kyle Taulton.
Re: Speedometer ?'s
« Reply #1 on: August 04, 2011, 04:29:42 pm »
I dont know if they did, but that would be helpful in determining the original mileage of a truck.
Offline ehjorten
Re: Speedometer ?'s
« Reply #2 on: August 04, 2011, 05:53:11 pm »
1991 would have been an electronic speedo with a 6 digit odometer, just like my '91 V3500.
-Erik-
Re: Speedometer ?'s
« Reply #3 on: August 04, 2011, 08:53:14 pm »
That is exactly what I want to do especially with my extended cab.  I have one from my 1991 parts truck that I would like to have converted if possible.
Offline ssapach
Re: Speedometer ?'s
« Reply #4 on: August 05, 2011, 10:54:45 am »
My 1986 has a 7 digit (XXX XXX.X) odometer, although it is in km's not miles.
Re: Speedometer ?'s
« Reply #5 on: August 05, 2011, 11:15:51 am »
Interesting, I wonder if the guts and face can be swapped over for miles???, any chance of posting a picture?
Offline ssapach
Re: Speedometer ?'s
« Reply #6 on: August 06, 2011, 04:27:58 pm »
I don't have a picture on my camera or work computer.  I might have one on my own computer, but I'll have to check when I get back to town after work.
If I don't have one on my personal computer then I'll have to take a picture when I get back home.  That won't be for another 6 days though.
Offline nucknoel89
  • Proud to be Canadian!
Re: Speedometer ?'s
« Reply #7 on: August 07, 2011, 12:41:30 am »
I think you'd probably have to change the gear or whatever that turns the numbers.  Our kilometres are shorter than your miles....
Offline ssapach
Re: Speedometer ?'s
« Reply #8 on: August 07, 2011, 07:57:37 pm »
This is the picture I happened to have......for what it's worth anyways.
Offline 1979C20
  • Kyle Taulton.
Re: Speedometer ?'s
« Reply #9 on: August 08, 2011, 02:55:28 am »
You could probaby take it to a shop and have them swap the gears to miles. 1.6mi = 1km
Re: Speedometer ?'s
« Reply #10 on: August 08, 2011, 08:01:57 pm »
Why not replace the sensor in the trans to work with the electric speedo.  If you are going to have cruise, they are much better.
Re: Speedometer ?'s
« Reply #11 on: August 08, 2011, 08:28:48 pm »
That would be great if there was step by step procedure written up to do that conversion.  My 91 Suburban has cruise and I am going to put the column in my 85 anyway.
Re: Speedometer ?'s
« Reply #12 on: August 08, 2011, 08:43:58 pm »
TBI's need a 2 pulse square wave.  You have 2 options if the 91 and the 85 have the same trans, just pull off the tails and swap the guts.
If not, get an adapter jags the run have a 2PRS http://www.jagsthatrun.com/Pages/SpeedSensors_Speedometer.html
