Author Topic: 4wd header ?  (Read 4680 times)
Offline biggietalls
4wd header ?
« on: August 04, 2011, 09:42:02 pm »
what sort of style of header do i need for a 77' 4wd? thought i knew what i needed but apparently i dont tried a set i had earlier and they both hit the motor mounts and the pass. side also hit my front driveshaft....
79'/88' k10 p/u
built 350/350/203
4:88 gears
msd. 6al
4"super lift
31"courser at2's
cobra 29 ltd classic-lil' wil
Offline ehjorten
Re: 4wd header ?
« Reply #1 on: August 05, 2011, 08:41:11 am »
I put in a set of Hedman Elite headers in my '77 K20.  They fit good, have 1/4" thick plate at the ports and have thicker wall tubing.  I would advice against the ball socket collector setup though.  They are constantly loosening up!  I have tried trick in the book to keep it from happening, but they start getting loose after about a month and I am back under there fighting them again.
« Last Edit: August 05, 2011, 12:35:01 pm by ehjorten »
-Erik-
Re: 4wd header ?
« Reply #2 on: August 05, 2011, 11:51:30 am »
I have a set of Thorley (not Dougs) headers and they fit great. They have thicker port flanges to help against warping.
Offline westsidek20
Re: 4wd header ?
« Reply #3 on: August 05, 2011, 12:02:25 pm »
I'm working on my truck now (78 K20), haven't placed them in yet, but the guy's at summit said that Hedman would fit. I'm about two weeks away from getting the engine back in the truck. I will let you know how it went.  ::)
Are you replacing all the exhaust? tubing and muffler?
