Author Topic: swapping rims  (Read 4665 times)
Offline lovetofish
swapping rims
« on: October 04, 2003, 07:39:00 am »
I have  a 1979 chevy 3/4 ton 2 WD with 16.5 rims.I would like to change to a more common rim.what rims will interchange
wheels and tires
Show results
Offline ammmotroop
re rim size
« Reply #1 on: December 22, 2003, 06:05:00 pm »
any size rim should work. common sizes could be 15x8,16x8 and so on. Just make sure that the tire size will fit if you are going to a larger tire or just get a tire that is a similar size to what you have just in the new rim size. Tirerack.com or any local tire shop should be able to help you with sizing.
