Author Topic: 1985 K-10 Front Driveshaft Grease Seal  (Read 24127 times)
Offline timl1978
« on: August 05, 2011, 12:21:12 pm »
Anyone know the part number for the seal that goes in the area shaded in the photo?  I believe it retains the grease over the splines...
Re: 1985 K-10 Front Driveshaft Grease Seal
« Reply #1 on: August 05, 2011, 08:14:28 pm »
I have never seen a seal. Might be wrong but I know I just grease till new grease comes out the splines where u circled
Offline 1979C20
  • Kyle Taulton.
« Reply #2 on: August 05, 2011, 10:00:05 pm »
From experience with the slip yoke in the middle of my 2 piece drive shaft, there is an oring inside of the dist cap on the female end of the drive shaft. That is what retains the grease. It slips onto the male end, you put the male in into the female end, and the dust cap threads onto the female end on the tip. I can post pics probably tomorrow if you need. But I believe the part you need is a Dust Cap.
Offline timl1978
« Reply #3 on: August 06, 2011, 06:03:02 am »
In the picture to the left the thing with the horizontal lines threads onto the male portion of the slip yoke.  The seal was within the cap.  It wasn't an o ring per se, more like a plastic or hard rubber seal...at least from what I could make of what was left of it.
« Reply #4 on: August 06, 2011, 07:37:48 am »
Buddy of mine made a new one for his truck out of jute carpet padding. It works pretty good. It not so much a seal as it is to keep dirt etc. out of the splines. When you grease them a little come out past. I have never seen and O ring in one but I'm sure if you got one that fit snug inside the cap it would work.
Offline mpullen66
« Reply #5 on: December 10, 2011, 03:13:05 pm »
I was replacing the carrier bearing on my drive shaft and noticed the same thing. It appears there was a plastic or rubber seal under the cap. I went to the parts store and they looked at me like I was stupid. Any ideas?
I have an 87 2wd lwb 700r4
Mike
1987 LWB,2WD,350,700R4  times 2
Offline 1979C20
  • Kyle Taulton.
« Reply #6 on: December 10, 2011, 05:40:42 pm »
Finally got a picture. I forgot about this thread. I guess it wasnt an oring.....
« Reply #7 on: December 11, 2011, 03:02:17 am »
never seen one like that i have seen a shock boot type of cove before
Offline rustymitchell
« Reply #8 on: December 11, 2011, 05:22:32 pm »
Check this link out from northern drivetrain:  http://www.northerndrivetrain.com/category/cat_misc_DustCapAssys.html.  They list the Spicer part numbers and sizes when you click on the part details.  I'm not sure which one it is you need but I'd put my money on the third from the bottom.  My truck had splined cork seals on the drive shafts but there's not much left of them now!  Once you get slop in your splines these where out quick.
79K20  350 sm465 np205
76C10  350 TH350
Offline mpullen66
« Reply #9 on: December 16, 2011, 12:04:12 pm »
Went to the local chevy dealership today. There is a seal under the cap. OEM part number 7827942.  $13.00 bucks!
Mike
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #10 on: December 17, 2011, 04:12:22 pm »
anybody know if that seal is the same as the one on a 2-piece rear driveshaft for a '78 3/4 ton?  I need one too.
Offline mpullen66
« Reply #11 on: December 19, 2011, 07:55:20 pm »
I would think its the same part
Mike
« Reply #12 on: December 21, 2011, 06:50:57 am »
     The other place to check would be a drive line shop, I bet they deal with them a lot.
