Author Topic: where can i get replacement gas tank straps  (Read 8193 times)
Offline tbarrii
« on: August 05, 2011, 03:42:01 pm »
i removed the gas tank to my 85(drivers side) and one of the sraps was broken.  any ideas where i can get replacements?  on the same token, the tank itself has some surface rust on it, what can i do to fix this before i re-instal the tank?  thanks
85 Chevy Silverado 1/2 ton 4x4 355ci
Online zieg85
Re: where can i get replacement gas tank straps
« Reply #1 on: August 05, 2011, 04:43:08 pm »
Contact Chris, he probably has a good source.  webmaster@73-87chevytrucks.com
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: August 05, 2011, 05:34:01 pm »
from Ford  :D
earlier this week they just recalled 50 trillion ford pickups because tank straps are rusting and tanks are falling out of the trucks.
Offline big bear
« Reply #3 on: August 05, 2011, 06:23:45 pm »
 :D
Online zieg85
« Reply #4 on: August 05, 2011, 06:31:54 pm »
from Ford  :D
Saw a 99 or so F150 at a state Route crossroads with all kinds of emergency response vehicles blocking the way.  Sure enough the gas tank was laying on the ground.
Offline gpday08
« Reply #5 on: August 05, 2011, 11:12:36 pm »
forr the tank some fine grit sand paper (wet sanding will save you some sandpaper) and some elbow grease I'd follow that up with a good parts cleaner and a good shot of a surface sealant, either primer or paint wouldnt hurt to do the whole tank while your at it to keep all rust off just make sure you have a good clean surface or the paint will just start to chip off
« Last Edit: August 08, 2011, 07:54:22 pm by Captkaos »
Offline tbarrii
« Reply #6 on: August 06, 2011, 10:46:13 am »
 ill give them a try  thanks for all the help
Offline thirsty
    • Suitor's Garage
« Reply #7 on: August 06, 2011, 12:27:53 pm »
Any auto parts store should have the straps available. If not this sites store should have them.
Offline gto109
« Reply #8 on: August 07, 2011, 08:45:05 pm »
i got mine from NAPA for around 25 bucks or so.
85 Scottsdale k-10 305 700r4,
86 Trans Am 305 350th
06 Dodge Ram daily driver
Offline black85k10
« Reply #9 on: August 08, 2011, 01:13:18 pm »
I got two at advance auto parts for around $50. Then Line-x the tank no more rust and the straps will not rub through the tank
85 chevy k-10 350 th400
« Reply #10 on: August 08, 2011, 07:56:13 pm »
I have them available right now, they are generally on back order but not right now.
I think I emailed you about this.
