Body, Glass & Paint
>:( headlight adjusters...
Topic: >:( headlight adjusters... (Read 10234 times)
gotsmeuhh350
August 06, 2011, 11:46:40 pm »
i bought 2 boxes of the plastic headlight adjusters, @ $5.40 a box. the first box, i put the first one in, and one of the tabs breaks off. so i drive 5 miles back to napa, and they give me another box for free, so i was happy with that. but the second box, i put the first one in, and yet another tab breaks off.
then i put the screw in the other one, and it strips. brand new, right out of the box. is there anyone who makes one out of metal? im sick of the plastic ones that dont last. well i may just buy a box of 25 from the store here, but id like to see if anyone can get metal ones. thanks in advance.
87 V10, 350 T350, 2 3/4 stacks, stock tbi (sold)
86 K10, 350 T350, headers, edelbrock carb, duals (scrapped)
86 C10, rust free roller, (sold)
86 C15, 305 700r4, stock. everything. daily driver/project
1979C20
Kyle Taulton.
Re: >:( headlight adjusters...
August 07, 2011, 03:49:45 am »
I use the black ABS plastic ones for license plates. Theyre softer and dont break as easy. Idk if they make metal ones.
gotsmeuhh350
August 07, 2011, 09:40:08 am »
wow. i was so mad i put this in the wrong section. lol. ive been thinking of a way to make a metal one. maybe itll work.
i was thinking, if i get a nut, that fits the screw/bolt for the adjuster, that fits tight into the rectangular hole on the truck, i can tack weld the nut to a little chunk of steel, to keep the nut from pulling forward. hmm. i may just have to try it. but where did you get the abs ones?
1979C20
Kyle Taulton.
August 07, 2011, 02:48:22 pm »
It was either oreillys or walmart. Theyre license plate mounts.
gotsmeuhh350
August 07, 2011, 10:36:52 pm »
alright, thanks. ill have to check there.
August 08, 2011, 08:07:42 pm »
Are you putting them in and pushing the bucket onto them or are you extended them all the way out and running tension on them.. I have used the plastic ones all the time.
Blazin
Blazin new trails!
August 08, 2011, 10:58:30 pm »
I have had the same problem with the ones from NAPA, and the same with some from two other parts stores. The black ABS strips out before you get the light into proper adjustment. I just run my plow lights year round because I have yet to find adjusters that are worth a crap.
August 08, 2011, 11:13:56 pm »
The ones I get are white plastic or Green (depending on the year)
The look like this:
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=HWB2108&Category_Code=7387FC
Skunksmash
August 11, 2011, 08:20:29 am »
Sourcing parts is always such a pain. You usually end up getting some chinese piece of junk that falls apart in your hands, or they want 10,000 dollars for a factory quality part at some specialty site. Its really rare that you can find quality parts for a reasonable price.
Last Edit: August 11, 2011, 08:22:17 am by Skunksmash
bowtieman82
August 17, 2011, 10:56:20 pm »
ive got mine fun the junk yard. OE one off a truck and they lasted me 5yrs so far. i just got to get me light lined up right.
Body, Glass & Paint
