Author Topic: cam choice for 383  (Read 6002 times)
Offline 305chevy c-10
cam choice for 383
« on: August 13, 2011, 10:35:05 am »
 my set up 750 dbl pumper or 600 holley ,vortec heads   with .550 lift springs  ,1.5 roller rocker ,hei distr,hv oil pump ,custom grind roller cam(215 intake  268 dur 110 lsa .490 lift )or thumper 283thr7 cam 227 IN/241 EX,513 IN /498 EX lift ,107 lsa,283/303 dur . and a 2000 or 2500 stall with 3.42 gears.rpm air gap dual plane intake .my question is what is a better cam for my setup ? another stupid question .if i have a custom grind cam done to the specs on a thumper will it lope like one . i know the custom cam i have will not have a nice lope to it .
Heartbeat of America yesterday's cheverolet
18T5C10
Offline Psycho71
Re: cam choice for 383
« Reply #1 on: August 13, 2011, 12:04:43 pm »
Thumpers are all about lope, not so much on the performance side of things. Why have a cam that sounds good, but runs like a dog? Go with a nice cam for performance, and take the lope you get with it. You'll be happier in the long run. My little ole 262 grind XE from Comp lopes fairly good for what it is, and will actually go when I jab on the long skinny pedal.
Call Comp Cam's tech line, give them your spec's, and tell them what you want the cam to do, and they'll tell you exactly what they have that will do the job. Great resource, and good guys that know their business. Once you see the spec's on the cam(s) they recommend, then start looking at the other manufacturers out there for something in the same range.
Offline 1979C20
  • Kyle Taulton.
« Reply #2 on: August 13, 2011, 07:01:57 pm »
I have a Comp Cams High Energy # 12-206-2  its a .440 lift 260 dur and it runs great. Its power range is 1200-5200. I really like the cam, but its on a stock engine so I dont know if it will work for you. Heres the rest of its specs  Comp Cams High Energy #12-206-2
« Reply #3 on: August 13, 2011, 07:13:28 pm »
the guy at comp cams said ,"i  think that the mutha thumpr is a great fit for you.  With the O.E. roller, I would look at part number 08-601-8.  The specs are duration @ .050 235/249 lift is .522/.509 with a 107 LSA.  The cost of the cam is $297.78 and I can cover shipping to the lower 48 states……  The roller will make a little more power for you and is more stable in the valve train…"..but is the .522 lift to close to my springs max lift rating ?i think the custom grind cam i have is faily close to the comps cam xe262 this one was recomended for my 355 .i also read that smaller cams do well in larger cid motors .
Gabriel Ray
Technical Consultant
COMP Performance Group™
3406 Democrat Rd.
Memphis, TN  38118
18T5C10
