Author Topic: random question about thermostat housing sizes  (Read 3370 times)
Offline txchainsawgogi
« on: August 13, 2011, 06:02:35 pm »
does anyone know where i can get a thermostat housing with a bolt to bolt distance of 7mm? i really need a metal tube neck/ flange combo... i was thinking a 350 housing would work but its about 1.5mm off.
Offline 1979C20
  • Kyle Taulton.
Re: random question about thermostat housing sizes
« Reply #1 on: August 13, 2011, 06:13:07 pm »
What application will it be used for? And  ould you enlongate the holes?
« Reply #2 on: August 13, 2011, 08:15:26 pm »
i was going to try and rig up some carb intakes for a motorcycle...and a tstat housing matches up almost perfect.
Offline 1979C20
  • Kyle Taulton.
« Reply #3 on: August 13, 2011, 08:23:31 pm »
In that case, I could recommend 3 things, cut it down the middle, bolt it in place, tac weld so you know the gap, then fill inbetween woth weld and grind it smooth. Elongate the holes. Take it to a auto parts store and see if they have any that bolt wider.
« Reply #4 on: August 14, 2011, 06:08:22 pm »
     Check with a local motorcycle junk/recycling yard.  I would think one off a old honda would be closer than an automobile.
