Engine/Drivetrain
2WD to 4x4
Topic: 2WD to 4x4 (Read 3906 times)
Elpresidente
2WD to 4x4
August 14, 2011, 06:42:40 pm »
I've got an '82 C10, and i'm considering a 4x4 conversion.
I know roughly what needs to be done, but I'm wondering if it's worth it or if i'm just wasting my time.
'82 Chev Scottsdale
Proud to be Canadian \m/
1979C20
Kyle Taulton.
Re: 2WD to 4x4
August 14, 2011, 06:56:57 pm »
Im planning on doing it. Most people on the forum wont recommend it. In short, youll need springs, spring hangers, front engine crossmember, trans, tcase, front axle, front steering components, steering box, high hump cab floor, trans/tcase crossmember, drive lines, brake lines. Heres what im planning on doing.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=20989.msg171540#msg171540
Blazin
Blazin new trails!
Re: 2WD to 4x4
August 14, 2011, 11:05:14 pm »
If your sheet metal is good, swap it onto a 4x4 frame.
WilliamBos
Re: 2WD to 4x4
August 20, 2011, 12:25:23 pm »
Check the area behind the steering box, below also. My friends father did it to an early 1980's Ram, took the driveline from a Ram Charger and put it into a Ram Chassis. You will need to make sure the axle ratios are the same.
Good luck.
Re: 2WD to 4x4
August 22, 2011, 09:22:33 pm »
Watch my Blazer Thread, I am doing it right now and you can see why I don't recommend it.
I
Engine/Drivetrain
2WD to 4x4
