Author Topic: Someone who is smarter than me  (Read 11959 times)
Offline reload
    • K & K Innovations
« on: August 15, 2011, 11:38:32 pm »
For the life of me I can't remember what this is called.  I believe there is a formula to represent it.
Lets say I have a range of numbers or steps
1 - 100
Each step adds value of 25
With an initial value of 50.
So
Step 1 = 50
Step 2 = 75
Step 3 = 100
Step 4 = 125
Step 5 = 150
And so on
What is that called?
Re: Someone who is smarter than me
« Reply #1 on: August 16, 2011, 12:04:59 am »
you mean like a "number sequence pattern"
Offline reload
    • K & K Innovations
« Reply #2 on: August 16, 2011, 12:06:54 am »
YES!  Let try something.
« Reply #3 on: August 16, 2011, 12:06:59 am »
« Reply #4 on: August 16, 2011, 12:08:10 am »
what are we going to try ;)
Offline reload
    • K & K Innovations
« Reply #5 on: August 16, 2011, 12:11:09 am »
Trying to write this in excel
« Reply #6 on: August 16, 2011, 12:12:31 am »
write what
Offline reload
    • K & K Innovations
« Reply #7 on: August 16, 2011, 12:13:57 am »
I want to map this in excel, using the example in the OP
Offline reload
    • K & K Innovations
« Reply #8 on: August 16, 2011, 12:14:32 am »
Offline 1980c10
« Reply #9 on: August 16, 2011, 12:23:51 am »
If you need a formula
try this;
50+(25 x's (Step#-1)) = X
Substitute values as needed. If this is homework use proper symbols and letters to represent the equation.
Offline 1980c10
« Reply #10 on: August 16, 2011, 12:26:35 am »
try this;
Ok still use this in the same format just reference cells where you enter your values with the "$" symbol
Offline reload
    • K & K Innovations
« Reply #11 on: August 16, 2011, 12:28:51 am »
Okay, I am closer, but here is the issue -
Using a growth trend I can quickly see that step 100 will equal 2525.  But now I need to show the total value spent per step.
50
75 =125
100 = 225
125 = 350
150 = 500
175 = 675
and so on.
Offline reload
    • K & K Innovations
« Reply #12 on: August 16, 2011, 12:31:14 am »
Its not homework, well sorta.  I want the values to project total time to total cost.  Sadly this is for game, I am trying to figure out based on a absolute income how much and how long it will take to achieve the goal; that is step 100.
It also doesn't help that I am fighting my ambien to figure this out  :P
Offline 1980c10
« Reply #13 on: August 16, 2011, 12:34:45 am »
try to use a "linear" trend as this is a linear equation.
Or post back your formula and maybe someone can fix it.
Offline 1980c10
« Reply #14 on: August 16, 2011, 12:40:50 am »
You also need to enter a "min" and "max" for 1-100 to be to get a n/a value outside of the parameters if you want to be technical about it, otherwise don't worry about it.
