Author Topic: should i remove my spray in bedliner??  (Read 4314 times)
Offline pedigo78
  • Big Blue
« on: August 16, 2011, 11:27:21 pm »
So the bed of my truck already has a spray in liner but it looks like crap. Can i just get some more and touc hit up myself? I am thinking about getting the Herculiner (or whatever). Also I an thinking about pulling my carpet and spraying it, but then relaying my carpet down over. What do you think.
Sgt Pedigo USMC
Re: should i remove my spray in bedliner??
« Reply #1 on: August 17, 2011, 01:11:57 am »
i would try to match it up first “the brand” but it might have a problem bonding.
« Reply #2 on: August 17, 2011, 07:49:52 pm »
Herculiner is a waste of $$. As far as do it yourself spray in liners, SEM is the only way to go.
« Reply #3 on: August 20, 2011, 08:42:32 pm »
     I am with Blazin, herculiner is no good unless you are applying to fresh metal, then it works good.  Irish might also have a very good point on the bonding issue.  As far as taking it off, short of sand blasting it is a pain in the butt.  I know, I have tried several things to a professional install bed liner and I ended up sand blasting everything off.
