Author Topic: door glass  (Read 11935 times)
Offline bowtieman82
door glass
« on: August 17, 2011, 10:52:14 pm »
i put new doors and new weather striping on my truck and now my widows dont work like they use too. ive tried using the old weather stripping, and nothing changes. i put new motor in and the same stuff. cant fix it need help.
Offline topp
Re: door glass
« Reply #1 on: August 18, 2011, 01:21:29 am »
Did you use the regulator from the old doors or the new?
'90 Suburban TBI 350
Offline bowtieman82
Re: door glass
« Reply #2 on: August 18, 2011, 09:26:27 am »
i used the old one.  the only time it goes up and down is when there is no weather stripping in it
Re: door glass
« Reply #3 on: August 18, 2011, 01:47:16 pm »
What year weather stripping and what year doors, and what year glass?
Offline bowtieman82
Re: door glass
« Reply #4 on: August 19, 2011, 08:46:44 pm »
ever thing is for 1982 chevy
Re: door glass
« Reply #5 on: August 22, 2011, 09:26:26 pm »
It is binding going in both directions?
Offline bowtieman82
Re: door glass
« Reply #6 on: August 26, 2011, 12:18:33 am »
my right side dont like to go up or down. the left side will go down fine but up really slow. can the chanel the weather stipping in not the right size.  or do i need to buy weather striping from year one, classic truck. ive been work on it ever since i put the new doors on. that was four years ago. it sat for two years. now im trying to fix my truck and this is the only thing i cant figure it out.  ive replace the runners, or guids, the regulater, the wheels on the regulater, i greased the wheels and nothing. i thought replceing the weather stripping was going make my truck better but all it did was make more work. im about to go out to the junk yard and see if one from a old truck will work better. i f--- tired of this.
« Last Edit: August 26, 2011, 12:30:18 am by bowtieman82 »
Offline topp
Re: door glass
« Reply #7 on: August 26, 2011, 02:11:33 pm »
Did you rebuild the regulator with new rollers?
Did you make sure the guide track at the back side of the glass inside the door panel itself is aligned correctly?
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: door glass
« Reply #8 on: August 27, 2011, 01:48:36 pm »
If you got the wrong weatherstripping, here's a pic of the differences between the two.  73-80 trucks had thicker glass and needed thinner rubber seals, 81-up had thinner glass and needed thicker rubber seals.
here's a pic of the two side by side. (73-80 on top) (81-up on bottom)
Offline bowtieman82
Re: door glass
« Reply #9 on: August 28, 2011, 08:23:17 am »
would the glass from a 73-80 look the same as the 81-87 glass. because ive had them replace along time ago my be that my problem they use the wrong year of glass. can u messure the glass. and whats the difference.
Offline 1979C20
  • Kyle Taulton.
Re: door glass
« Reply #10 on: August 28, 2011, 07:49:03 pm »
Either weather stripping would work for the 81-87 glass, it would just be loose in the channel with the 73-80 stripping. But only 73-80 weather stripping would work for 73-80 glass since its too thick for the 81-87 glass. you probably have 73-80 glass with 81-87 weather stripping.
Offline bowtieman82
Re: door glass
« Reply #11 on: August 28, 2011, 10:56:32 pm »
oka ill go buy two pieces of glass at the junk yard. and see if that helps. thanks
Offline Dr_Snooz
Re: door glass
« Reply #12 on: August 30, 2011, 10:28:51 pm »
Hit the felts with some silicone spray before you spend any more money.
