Author Topic: no spark no fuel i need HELP please!!!!!!!!!!  (Read 14818 times)
Offline Twades87chevy
« on: August 18, 2011, 10:20:16 pm »
ok i have a 1987 chevy 350 tbi 5.7 one ton pickup. the truck run great the night before but this morning the truck will not start. i have a tank full of gas. theres no gas coming out of the tbi at. and it has no spark. i have no clue what went wrong on it. i need your help this is my daily driver. if u need more info just ask. thanks so much for your help.
Offline rsandusky
Re: no spark no fuel i need HELP please!!!!!!!!!!
« Reply #1 on: August 18, 2011, 10:40:45 pm »
No spark, no injector pulse: 1 Verify voltage to the coil. 2. test ignition module and/or replace 3. if you have voltage and the ignition module is good, check for an open or shorted pickup coil.
This is where I would start.
« Reply #2 on: August 19, 2011, 05:26:13 am »
i have voltage to the coil and i tested the ignition module at the parts place it passed. i might need to replace the pickup coil. but would this keep the tbi injectors from firing gas out. everything on the truck works fuel pump, lights , radio, starter, ac, etc. its just has no spark and the gas is not coming out of the injectors.
« Reply #3 on: August 19, 2011, 06:54:49 am »
the icm send a signal to the pcm for spark and pulse. even if it test good it can still be bad
« Reply #4 on: August 20, 2011, 09:44:57 am »
could my computer be bad
Offline rsandusky
« Reply #5 on: August 20, 2011, 10:27:22 am »
The computer doesn't control the spark until the engine starts, then it is controlling the spark advance not whether or not it has spark.
Offline topp
« Reply #6 on: August 20, 2011, 12:33:40 pm »
ICM and/or Pickup coil are the usual culprits for this problem....
'90 Suburban TBI 350
« Reply #7 on: August 20, 2011, 04:18:18 pm »
ok cool im glad i found that out i was about to go buy a new computer. so does the pickup coil have any thing to do with my injectors not shootin gas.
« Reply #8 on: August 20, 2011, 08:44:49 pm »
The icm does
Offline rsandusky
« Reply #9 on: August 21, 2011, 08:00:40 am »
The icm does
Yes. The pickup coil is mounted inside the distributor and gives a signal to the Ignition Control Module (ICM). That signal is processed  by the ICM to control the spark and is passed to the computer to control the injector pulse.
« Reply #10 on: August 21, 2011, 08:40:16 am »
Man thank all so much I'm buying one 2 day. I'll let y'all know if that works
Offline rsandusky
« Reply #11 on: August 21, 2011, 10:33:45 am »
FYI- The pickup coil can be tested with a simple ohm test.
Post back if you want details.
« Reply #12 on: August 21, 2011, 11:30:12 am »
that was it i got a new pick up coil and new icm its running great thanks for the help
« Reply #13 on: August 21, 2011, 11:47:24 am »
just for shots  ;) and grins get the coil tested. to see if it was bad
