Author Topic: 10 bolt rebuild parts  (Read 8768 times)
Offline frotosride
    • WFO CONCEPTS
« on: August 19, 2011, 09:54:52 pm »
I've been looking for everything i need to rebuild the knuckles and auto-locking hubs on my 10 bolt 8.5. Is there a place where i can get the upper and lower ball joints, bearings and even the u-joints at the knuckles. I figure if I taking it apart might as well only do it once. I also need new Tie-rod ends as all the steering components are originals and have been caked in grease and dirt for who knows how long '87 v10 350 tbi. I have found a few places where i can get the lower ball joints but not the upper' I'd like to order from one place if possible. Thanks for the help guys. oh and upgrades are welcomed ??? i'm new to the 4-wheel drive community and this is the first sfa that I've worked on. Given that how do i find the right type/size u/cv-joints for the front axle. mine desperately need to be replaced and i can't think of a better time to do it.
« Last Edit: August 19, 2011, 10:08:26 pm by frotosride »
Offline snibook7537
  • Vince Ziolkowski
Re: 10 bolt rebuild parts
« Reply #1 on: August 20, 2011, 12:35:01 am »
Autozone or Advanced Auto parts is where I would go first.  Then to Napa or an AC delco store if they didn't have something
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
« Reply #2 on: August 20, 2011, 03:08:58 am »
upgrade: get manual hubs but yeah autozone should have it all if not should be able to order it. about the u joint its either 2-3011 or 1-0153 on my 79 its only 1-0153 all three are the same but i think its saying that 2-3011 is for the 2 in the cv joint while 1-0153 is for the front axle yoke joint. i would take my old ones in to match them up
Offline rustymitchell
« Reply #3 on: August 29, 2011, 08:28:45 am »
If you're into mail ordering parts or just want to look around at what's out there try Summit, Randy's Ring and pinion, Denny's Driveshafts, Quad 4x4.  Google them for the websites.  They all have good online catalogues.  I ordered everything I needed for my 10 bolt from these four companies (including some tools from Quad 4x4).
79K20  350 sm465 np205
76C10  350 TH350
« Reply #4 on: August 29, 2011, 07:31:43 pm »
     I am finishing my dana 44 front end, I got most all parts at auto zone, but when I went to get the 1 piece rotor/hub assy's, they said they no longer stock them.  I got them at o'rielly's, along with the spindle bearing kits ( spindle bearing, beariing seal, spacer,and the outer larger seal) all in a package.  Part number SBK1 at O'rielly's.
Offline frotosride
    • WFO CONCEPTS
« Reply #5 on: October 14, 2011, 08:41:54 pm »
Thanks a lot guys. i ended up getting most of my parts from   truck and a few from Denny's driveshafts....in all e spent just over $600 but that is all steering components, front axle shaft u-joints, poly bushings frnt & rear, knuckle ball joints, tie-rods and draglink, all hub/rotor bearings and seals plus shocks all the way around.....now i just wish i had a buddy around that likes free beer and i trusted to help me....you can't teach someone to be mechanically minded!! ;D
« Reply #6 on: October 14, 2011, 09:35:09 pm »
     That or HOW TO BE SAFE WHILE WORKING AROUND YOU, some people just don't get it.  I had a guy interview with me about 4 years ago, said he worked on airplanes.  When I asked him to hand me an adjustable wrench, he stared for awhile and picked up the water pump pliers.  He didn't last any longer than for me to say no way
