Author Topic: Gas tank sending unit...  (Read 3060 times)
Offline hotrod24
« on: August 26, 2011, 03:38:46 pm »
Has anyone ever fixed a ground wire on one of these, Mine snapped right at the starting of the wire?
1978 pontiac grand prix...
Offline 1979C20
  • Kyle Taulton.
Re: Gas tank sending unit...
« Reply #1 on: August 26, 2011, 04:08:11 pm »
If you clean up the area you could probably solder it back on to the sending unit. And I dont know if this would be acceptable, but im sure someone on the forum will say yes or no, but you could probably put a terninal lug on the end and use a self tapping screw to screw it into the top of the sending unit.
« Reply #2 on: August 26, 2011, 08:24:58 pm »
    79c20 is right, either way will work if done right.  I prefer to replace, but I have soldered one before and it lasted a long time.
