Author Topic: selectorvalve question  (Read 9580 times)
Offline JDaniel
« on: August 29, 2011, 12:25:53 pm »
hello all,
I needed to replace the selectorvalve, the old one was with 1 wire ,the new one is 6wires, can i just connect the 1 wire who switches from 0 volt to 12 volt to 1 of the six wires ,or do i need to connect them all?
does the valve work like the old types , just switching when 12 volt is sent?
who can help??
« Last Edit: August 29, 2011, 02:16:12 pm by JDaniel »
Offline muddpuppy01
Re: selectorvalve question
« Reply #1 on: August 29, 2011, 02:45:38 pm »
from the wiring diagram that I had when I replaced mine the valve switched from reversing the polarity of two of the wires dont know which one off hand
Offline JDaniel
« Reply #2 on: August 29, 2011, 02:55:01 pm »
so if i understand it correct , you connected the 1 wire from the old valve to 1 of the wires(6) from the new valve?
« Reply #3 on: August 29, 2011, 07:18:42 pm »
     Why does your old one have 1 wire and the new one has 6 ?  Do you have the right selector switch ?
« Reply #4 on: August 29, 2011, 08:07:40 pm »
i think he got a universal one
Offline JDaniel
« Reply #5 on: August 30, 2011, 12:28:07 pm »
hi all ,
 my switch sends 1 wire to the valve where i can put 12V on it.
(the old valve had 1 connection)
the store in belgium ordered a new valve at   usa and they told that the old type is not longer avialable so they sent a 6wire valve, but that needs 2 wires where i can put 12 v on it, i'm gonna try to change my switch so i can use the new valve ,i think i need 2 wires where i can put 12V on it
first stand= 12v to 1 wire
second stand= 12v to the other wire
i think that is the solution.
is their anyone who changed his 1wire valve to a 6wire type without changing the switch?
i checked the switch and i think i can put a second connection in ,so i'm gonna try that first.
sorry for my bad english
grtz from a little country (Belgium)
Pete
Offline muddpuppy01
« Reply #6 on: August 30, 2011, 01:03:23 pm »
You will need to switch the polarity of the wires
The following is just a example. Which would switch tanks and not the gauge.
Left tank
Wire A = +
Wire B = -
Right tank
Wire A = -
Wire B = +
Offline JDaniel
« Reply #7 on: August 30, 2011, 02:04:58 pm »
yes ok thx, i'm now searching wich kind of switch i have to use .
the easiest way is keep the old switch to operate the gauge and to mount a 2nd switch to operate the valve.
thx for the help
« Reply #8 on: August 30, 2011, 03:16:17 pm »
check with pollak for the correct part. It is where I got mine.
Offline heavychevy91
  • '86 Chevy K20
« Reply #9 on: August 30, 2011, 05:18:47 pm »
This one is almost identical to the Pollak one Beastie is talking about. one wire hook-up https://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=CRB22057_0213452235&An=0
« Reply #10 on: August 30, 2011, 05:21:51 pm »
yup, thats the one.
  • '86 Chevy K20
« Reply #12 on: August 30, 2011, 05:25:38 pm »
heres the one i think he might have
http://www.autozone.com/autozone/parts/1986-Chevrolet-K10-1-2-ton-P-U-4WD/Fuel-Tank-Selector-Valve/_/N-ij1qkZ8ve9x?filterByKeyWord=selector+valve&fromString=search
Irish i think thats the one he was looking to use that one because he couldnt find the one wire hookup. i think
« Reply #13 on: August 30, 2011, 05:41:29 pm »
yeah i was under the impression that he ordered it and picked it up but i did just wake up so i wasnt reading it right lol
  • '86 Chevy K20
« Reply #14 on: August 30, 2011, 05:47:42 pm »
ahhh okay gotcha
