Author Topic: np205 gears  (Read 7318 times)
Offline pedigo78
  • Big Blue
np205 gears
« on: September 02, 2011, 07:29:02 am »
I have an 85 k20. so i was wondering did they make any np205 that are full time full wheel drive. I was doing some work on my transfer and put it all the way forward which should be 4lo everything was good, then i pulled back it was nuetral, then pulled back again and two wheel drive. well thats all the pulling i can do, so i put it back forward to see if i was just missing a gear but it alwys went from lo to nuetral. i dont know anyone have an idea.
Sgt Pedigo USMC
Re: np205 gears
« Reply #1 on: September 02, 2011, 09:52:19 am »
     The 205 did not come full time.  Has your transfer case ever been rebuilt ?  Sounds to me like it might need it if you can not shift into all the gears.
Re: np205 gears
« Reply #2 on: September 02, 2011, 10:59:18 am »
clean and lube shift linkage before rebuild...
Offline pedigo78
  • Big Blue
Re: np205 gears
« Reply #3 on: September 02, 2011, 02:21:08 pm »
Yeah, i will play with it again. maybe i was just missing it.
Sgt Pedigo USMC
Offline heavychevy91
  • '86 Chevy K20
Re: np205 gears
« Reply #4 on: September 02, 2011, 05:17:28 pm »
Heres the shift pattern so if your getting it into 4 hi your going past 2 hi
http://www.chuckschevytruckpages.com/images/NP205knob.jpg
Re: np205 gears
« Reply #5 on: September 03, 2011, 12:43:04 am »
like beast said mud can get up into the linkage and not shift right. also someone on here had a problem where the shifter handle was hitting the floor causing it not to shift right
Offline pedigo78
  • Big Blue
Re: np205 gears
« Reply #6 on: September 03, 2011, 07:11:39 pm »
Yeah, I went and played with it some more and I think it is fine now. Thanks for yalls help
Sgt Pedigo USMC
