Engine/Drivetrain
5.30 Swap Into My 85 4x4????
Topic: 5.30 Swap Into My 85 4x4???? (Read 5288 times)
jsyocum
September 08, 2011, 02:51:47 am »
I'm looking to put a 5.3 and 4l60E in my 4x4 85 Chevy truck. What do i need to know? I have to motor and trans form a 99 Chevy truck and a harness form an 01-02 truck. What will i need to do the swap and how hard in it going to be because most i have looked at were 2wd swaps.
williebm3
Re: 5.30 Swap Into My 85 4x4????
September 08, 2011, 09:52:41 am »
First research google and all avenues about this swap. Second, I would say start looking for a drivers side drop axle.
September 08, 2011, 11:53:57 am »
You will have to mate a 73-87 T-case to the trans, the NP241 came behind the 4L60E.
There is some info in the forum on putting one in a 4x4. LS1Tech probably has alot of info, but post back your progress.
jsyocum
September 08, 2011, 10:55:46 pm »
Thats the only part im not sure about if my 208 will bolt up where the 241 is now? Other than that i picked up a whole chassie from a tahoe today with all the wiring to here it run with out the body so i think i have every thing to do the swap.
September 12, 2011, 06:07:22 pm »
I think the later 208 will work. I have swapped a 241 to a 208 before.
muddpuppy01
September 12, 2011, 09:49:42 pm »
I am under the impression that the 241 and 208 were of the same input and bolt pattern
jsyocum
September 14, 2011, 06:26:38 am »
Good thats what i thought but i wasnt sure.
GP3624
November 14, 2011, 02:37:04 pm »
The 208 transfer case will bolt up noooooo problem....
Engine/Drivetrain
