Author Topic: 12 bolt  (Read 15773 times)
Offline muddpuppy01
Re: 12 bolt
« Reply #15 on: September 15, 2011, 04:36:06 am »
I would use the 3.42 gear that you got now
Offline str8bloc
  • MISTRESS
Re: 12 bolt
« Reply #16 on: September 15, 2011, 07:37:36 pm »
i have 2.73 in the truck the rear i just got has 3.42, ima go through the rear. all new seals hardware etc. so should i keep the 3.42 or just swap the 3.73?
FaTbOy
Offline 80stepsideguy
Re: 12 bolt
« Reply #17 on: September 15, 2011, 08:25:55 pm »
3.73s are good if you got a 4 speed or a 700r4 .Any 3 speed  like a th350 or 400 is not good cause of the aggressive rpms it produces.If you got a 3 speed auto go with the 3.42.
thanks
pat
1998 Chevy 1500 S/B 2wd
Re: 12 bolt
« Reply #18 on: September 15, 2011, 08:54:39 pm »
What size tires are you running and what trans? I agree with Pat unless it's just a toy. If it's a toy go with the 3.73
Offline str8bloc
  • MISTRESS
Re: 12 bolt
« Reply #19 on: September 17, 2011, 12:43:25 pm »
wanna make it a street truck 700r4 i want 4.11 but 3.73 would do for the time being
FaTbOy
Re: 12 bolt
« Reply #20 on: September 17, 2011, 04:03:35 pm »
What size tires are you running?
Offline str8bloc
  • MISTRESS
Re: 12 bolt
« Reply #21 on: September 17, 2011, 08:10:19 pm »
oh my bad they are 205 70 15 for the front and 235 75 15 for the rear. i wanna run 205 70 15 for the front and 295 or 325 50 15 on the rear for daily and  a 28 10.5 radial for the track
FaTbOy
Offline str8bloc
  • MISTRESS
Re: 12 bolt
« Reply #22 on: March 20, 2012, 11:00:56 am »
well my buddy wants my 10 bolt he blew his 12 bolt do i use the same hybrid joint?
FaTbOy
Re: 12 bolt
« Reply #23 on: March 20, 2012, 01:26:30 pm »
Yes
