Author Topic: Engine cranks but making a loud rattle sound from carb  (Read 6682 times)
Offline Mr84c10
« on: September 12, 2011, 06:49:10 pm »
Oh so am bk again... so I adjust my valves the right way change spark plugs and finally got my truck to crank after I notice fuel pump wire was loose... fix that finally cranked and now am getting a loud rattling noise like theres something in carb.... I don't hear any other weird noise coming from engine just that one noise from top that sounds like its from carb engine will run for a MIN or so than shut off... am running 350 .60 over wit a 750 edelbrock carb fuel pump is unknown.... but fuel pump is working now just the loud noise and not running 4 long
Sent from my SCH-I500 using Tapatalk
Re: Engine cranks but making a loud rattle sound from carb
« Reply #1 on: September 13, 2011, 01:44:04 am »
the only thing i can think of rattling noise is the floats. is it only doing this while running?
Offline Mr84c10
Re: Re: Engine cranks but making a loud rattle sound from carb
« Reply #2 on: September 13, 2011, 07:44:49 pm »
Ya but I can't even drive it runs MIN or so then shuts off
Offline Mr84c10
« Reply #3 on: September 14, 2011, 10:33:13 am »
dang nobody else knows
« Reply #4 on: September 14, 2011, 01:21:25 pm »
If you babe a problem with the float it might flood the engine causing it to stall
Offline wildcatjason
« Reply #5 on: September 14, 2011, 06:29:33 pm »
Is something loose causing a vacuum leak has well? I don't know what would rattle on a carburetor except something attached to the carburetor.
Offline Mr84c10
« Reply #6 on: October 04, 2011, 07:39:23 pm »
Am going put a new carb on it and hope for best
Offline slammed79
  • Thou shalt not drive stock
« Reply #7 on: October 04, 2011, 07:48:07 pm »
Why not rebuild the one that is there? A carb rebuild kit is much cheaper than a new carb. And it can be done with hand tools and a can of compressed air.
Praise the lowered
