Author Topic: power window regulators (year differences)  (Read 3704 times)
Offline p7387
« on: September 13, 2011, 02:33:02 am »
looking to switch the passenger side manual regulator to power. i have a 87 2wd so what year donor truck will have the regulator i need.
i ask this because i see   splits the years for power regulators from 77-81 and 82-87
thanks
Offline slmdchvy05
Re: power window regulators (year differences)
« Reply #1 on: September 13, 2011, 03:01:40 pm »
Im not sure what all years are the same, but I have a 84 and swapped all the internal out from a 91 suburban and they all work no problems the plugs are the same for the regulator but when you go down the wiring harness the plugs are different. If you get a donor and the plugs are different all you have to do is pull the pins that the wires are connected to out of one plug housing and put them in the other plug housing.
84 Bagged trud rollin 16's
« Reply #2 on: September 22, 2011, 11:19:55 am »
They say the 77-81 motors are better, either should swap though...
