Author Topic: what is ?  (Read 6025 times)
Offline 305chevy c-10
what is ?
« on: September 16, 2011, 07:16:44 am »
this may be a dumb question but .what is the ball looking thing under the hood on the driver side .i know it has a vac line to it .i just changed the intake and carb off my 305 and now hooking lines back up .i think i got it right . distr vac to timed vac on (600 holley)carb ,pvc port on carb to pvc  on driver valve cover ,trans vac and power brake vac on vac port on(edelbrock ) intake .now i just gotta figure how to set timing .was at home bored so i used some parts i had laying around
Heartbeat of America yesterday's cheverolet
18T5C10
Re: what is ?
« Reply #1 on: September 16, 2011, 09:03:13 am »
this?
18T5C10
Offline topp
Re: what is ?
« Reply #2 on: September 16, 2011, 12:22:16 pm »
Vacuum canister.
'90 Suburban TBI 350
Re: what is ?
« Reply #3 on: September 16, 2011, 12:37:35 pm »
Vacuum canister.
For the AC controls inside the cab to operate the vents/defrost dampeners.
Re: what is ?
« Reply #4 on: September 16, 2011, 02:10:17 pm »
where does it need to be hooked to
18T5C10
Offline bowtieman82
Re: what is ?
« Reply #5 on: September 16, 2011, 10:43:27 pm »
it hooks up on the card. there a small port that has vac. all the time.  on holley it on the passenger side on edelbroke its on the right front side. q jet u will have to use a vac. gauge to find it.  and that ball thing is for vac. controls on your heater/ac it helps to keep the vac. at a steady level so your controls work the same all the time. if u dont have it, when u are driving around sometime u will be able to change the setting and some time not.
Re: what is ?
« Reply #6 on: September 17, 2011, 08:12:10 am »
ok thanks i will buy some more vac line and hook it up .u r talking about a full vac port right .its the small port thats comes capped when u buy a holley ?
18T5C10
