Author Topic: gathering parts for 383  (Read 4725 times)
Offline 305chevy c-10
« on: September 16, 2011, 08:58:44 am »
almost got all my parts for engine ;
*87-95 rollerblock 2 bolt main (studded mains )
*cam (roller) 268 @.490 lift
*vortec EQ heads ,screw in studs withguide plates ,1.5 roller rockers nonself align
*melling hv55 oil pump and pick up
*7 quart oil pan
*silverlite dished pistons .030
* stock rods with arp bolts
*eagle cast steel crank( 103523750)
*400 pioneer flexplate (fra-159)
*summit 400 balancer with removerable weight
*clevite rod and main bearings
*hasting rings
*elgin timing set
*pro comp hei distri
*air gap hi rise dual plane intake
*600cfm holley
*spectre dual carb hat (custom cold air ducts )
Heartbeat of America yesterday's cheverolet
18T5C10
Offline low budget
Re: gathering parts for 383
« Reply #1 on: September 16, 2011, 09:15:23 am »
Sounds good, keep us posted 8)
« Reply #2 on: September 16, 2011, 10:08:06 am »
     So your going to pull out the 305 ?
« Reply #3 on: September 16, 2011, 11:49:04 am »
yep clean it up a little and put in a regal or s10 .i think it will perform better now because that egr portonintake was full of crud and gunk.lifter valley was clean except for chunks of that crud
18T5C10
« Reply #4 on: January 13, 2012, 07:57:32 pm »
happy now ...all machine work complete just got get it all put togather now .can't wait  ;D :D
18T5C10
« Reply #5 on: January 15, 2012, 07:54:05 pm »
Hurry up!
