73-87 Chevy & GMC Trucks
rotors-must they be replaced in pairs ?
Topic: rotors-must they be replaced in pairs ? (Read 6587 times)
p7387
September 20, 2011, 06:19:09 pm »
hello:
installed new calipers,pads,hoses and noticed one rotor was bad (pitted on the inside) so i replaced it. the other rotor is in good condition so i was going to leave it alone. must rotors be replaced in pairs? i recently spoke to someone concerning this and they insisted they should be replaced in pairs.
what are your opinions?
thanks
zieg85
Re: rotors-must they be replaced in pairs ?
September 20, 2011, 06:24:21 pm »
IMO, no. I worked at a Muffler and Brake shop and if they were in tolerance they were good to go. I have replaced just one rotor when doing brake jobs on several of my own vehicles over the years and had no issues...
Da67goatman
Site Supporters
Burban
September 20, 2011, 08:03:55 pm »
They don't HAVE to be replaced in pairs, it is possible to get pulls having one new and one used, so I always replace them in pairs.
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
September 21, 2011, 01:13:10 am »
im with these guys i never had to replace both rotors. only replace them if they are bad. even my moms e150 has a gouge in it from a rock getting jammed in the pads replaced the pads and left it alone still doing good this was back in 02-03. most times the only need to replace a rotor imo is if you need to replace bearings or something is frozen up
slammed79
Thou shalt not drive stock
September 21, 2011, 01:46:28 am »
Depends for me how much cash I have on me when I get to doing the brakes, or if one is shot and the other is close to being out of spec.
Praise the lowered
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
September 21, 2011, 12:45:54 pm »
the answer is no. In fact, i wouldn't replace the first one unless absolutely necessary. They can be turned for a new surface if they are still within specs.
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
bake74
September 21, 2011, 09:12:58 pm »
Just like everyone else said, if you take your rotors to be turned, they do not always come back to you with the same thickness, depends on how much they have to grind off to get the warpage, scars, etc. out.
74 k10, 77k10 Tom
