Author Topic: Hi  (Read 6366 times)
Offline Sodium Duck
Hi
« on: September 22, 2011, 09:51:22 pm »
Been wanting a 73-87 Chevy since before I could drive. The time was finally right. Picked up an '85. Regular cab, longbed, carbed 305 with a manual choke, 1/2 ton 10 bolts, 6" lift, automatic. Needs finishing and minor work. But I'm looking forward to learning how to do it all. Never done anything beyond changing oil and rotating tires. But I picked up a Chilton book so I should be fine. Tomorrow I start tearing down the front axle so I can install my new moog ball joints.
It's going to be a slippery slope though... I'm already thinking to myself, well I may as well change out all the tie rods too... and if I'm doing that I may as well get a high steer kit... and if I'm doing that I should probably get new bearings, rotors, pads, buy a grinder and some paint, new manual hubs, chromoly shafts, new u-joints... wow this just got expensive! Ugh...
1985 K10, corporate 10-Bolts front and rear, 6" lift, 35's, 305, auto, longbed.
Offline Sodium Duck
Re: Hi
« Reply #1 on: September 22, 2011, 09:52:56 pm »
pics
Offline slammed79
  • Thou shalt not drive stock
Re: Hi
« Reply #2 on: September 22, 2011, 10:36:52 pm »
Add a set of 35's and you'll be just about money. Good lookin truck bro!
Praise the lowered
Re: Hi
« Reply #3 on: September 23, 2011, 03:50:23 am »
Welcome from NW Indiana
Offline big bear
Re: Hi
« Reply #4 on: September 23, 2011, 05:50:48 am »
welcome from northeast ohio. great looking truck.   yup, you will get bit by the bug and then its over haha
Re: Hi
« Reply #5 on: September 23, 2011, 06:29:55 am »
     Welcome from California.  This is a great site to find info/expertise that you will need for your rebuild.
Offline Sodium Duck
Re: Hi
« Reply #6 on: September 23, 2011, 11:10:27 am »
Outer lock rings are stupid. What's the trick to getting them out?
Offline thirsty
    • Suitor's Garage
Re: Hi
« Reply #7 on: September 23, 2011, 01:13:00 pm »
I use two really small screwdrivers keeping one under the lock ring while I work one around the hub. I also use my pocket knife to get under them so I can fit the small screwdriver in the first time.
Offline 69byrd
  • Haulin!
Re: Hi
« Reply #8 on: September 23, 2011, 03:14:38 pm »
Welcome from Tn
Offline Sodium Duck
Re: Hi
« Reply #9 on: September 23, 2011, 05:24:16 pm »
I asked my next door neighbor for a pick or something similar, he gave me a tool - it's literally a dentist tool. The one they use to scrape all the crap off your teeth. Worked great. I may try a knife on the other side though, that sounds like it would work too.
Offline DustyRusty
Re: Hi
« Reply #10 on: September 23, 2011, 05:33:17 pm »
Welcome from Alaska.
Nice lookin' truck.  Sounds like you have a plan for R & R'ing the front end.  I also found it to be beneficial to make out a budget for covering items necessary for the safe operation of the vehicle and then another budget for "while I'm at it, I might as well...".  A budget plan helped me to prioritize the truly necessary work.
Rusty
Customized by rust.
