Author Topic: Electrical Conection  (Read 3733 times)
Offline apchas
« on: September 24, 2011, 10:56:18 am »
I just changed out a 305 to a 350 in my 1984 Chevy SB 4x4. I have to connections that I don't know where they go. First is a Red 2 pin connector. 2nd is a 4 pin connector with green seal near the back of the engine. Where do they go. I did not see any open plugs. I checked the kick down and its hooked up. Engine runs and drives good.
Re: Electrical Conection
« Reply #1 on: September 24, 2011, 08:59:58 pm »
     First I would ask for pics, so we can see the plugs (and if they are standard), second I would ask if all your gages work, and does everything still work that did before the swap ?
Offline apchas
« Reply #2 on: September 25, 2011, 09:38:37 am »
The truck was not running what I got the truck. The truck was sitting for 5 years. The only gauge that is not working good is the water temp and gas gauges. I know the sensor for the temp gauge is not mounted in the engine.  I am still working on engaging the 4 wheel drive.
http://www.flickr.com/photos/67908167@N05/6181736659/in/photostream/
http://www.flickr.com/photos/67908167@N05/6181735917/in/photostream/
« Last Edit: September 25, 2011, 01:27:26 pm by apchas »
« Reply #3 on: September 25, 2011, 02:58:10 pm »
     The (2) pin looks like it is really only 1 wire which to me looks to be an inline fuse wire, the four pin set up looks to be for trans, do you have a auto trans ?  Have you traced where these wires go, that way when others look at this thread they might have a better answer for you.
Offline apchas
« Reply #4 on: September 25, 2011, 05:03:17 pm »
The 4 pin gown into the harness and gets lost. the 2 pin has two wires. 700R4 Automatic. Does the 2 pin go to the MP208? I saw in another post a connection on top of the gear box? I do not have a light on the dash for the 4x4 engaged?
