Author Topic: voltage guage  (Read 6817 times)
Offline bigchevyc30
  • the pig
voltage guage
« on: September 25, 2011, 06:01:34 pm »
OK so on my dually the voltage gauge is acting up it will stick sometimes when i drive my truck and when i tap on it it will go to its normal reading and since i got another gauge in my gauge cluster from autozone that came with the oil water and voltage and im wanting to make sure its reading right all the time. Please if you can tell me were to hook my wires up to ill greatly appreciate it
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline Got Smoke?
Re: voltage guage
« Reply #1 on: September 25, 2011, 09:47:11 pm »
In my sunpro trio cluster my volt gauge instructions told me to just hook it into a fuse on the fusebox. I just used a brass fuse tap that goes over the spade and has a male end sticking out above the fuse when installed. I believe the instructions said to put it on the top side of the fuse so it reads the voltage coming in. Mine works great
97 Dodge Cummins modded 12V
02 VW Golf TDI 40+ MPG
79 Chevy K20 350 4spd 5" lift 37 MT OZ's
88 Chevy V3500 / 88 GMC R3500 combo going 3+3 SRW 350/400/205
Re: voltage guage
« Reply #2 on: September 25, 2011, 11:12:29 pm »
either side of the fuse will work but the power one going in wont be protected and the other one will. but it seems you might have a faulty gauge.
Offline bigchevyc30
  • the pig
Re: voltage guage
« Reply #3 on: September 25, 2011, 11:27:21 pm »
this is y i am wanting to get the new gauge working so i know its right
Offline Got Smoke?
Re: voltage guage
« Reply #4 on: September 26, 2011, 06:44:25 am »
 :-X Yup....that makes sense too that's what I get for trying to go off memory. :D
