Body, Glass & Paint
shaving.
Topic: shaving. (Read 11526 times)
84chvy
shaving.
September 28, 2011, 09:06:15 pm »
well boys. i have decided to shave my mirrors and ran gutters. my question. where do i start?
Blazin
Blazin new trails!
Re: shaving.
September 28, 2011, 09:35:05 pm »
With unbolting them!
84chvy
Re: shaving.
September 28, 2011, 09:35:48 pm »
alright next step~
big bear
Re: shaving.
September 28, 2011, 09:40:36 pm »
beastie_3
Josh
Re: shaving.
September 29, 2011, 02:04:28 am »
weld up the holes.
Who's got step 3?
Semper Fi
onelow84
Re: shaving.
September 29, 2011, 05:24:09 am »
grind down the welds....and then!
firefighter
Re: shaving.
September 29, 2011, 06:30:44 am »
Skim coat with filler over any flaws or small pockets left over after the grinding.
1979C20
Kyle Taulton.
Re: shaving.
September 29, 2011, 07:01:34 am »
Then block sand the filler.....
low budget
Re: shaving.
September 29, 2011, 08:29:35 am »
Now this is what you call team work!!!
69byrd
Haulin!
Re: shaving.
September 29, 2011, 08:35:47 am »
Once satisfied with body work.....primer
bigchevyc30
the pig
Re: shaving.
September 29, 2011, 10:08:29 am »
then paint
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
78 Chevyrado
Z62 ON-ROAD
Site Supporters
Re: shaving.
September 29, 2011, 01:37:30 pm »
This made me think of a funny picture...
1980c10
Re: shaving.
September 29, 2011, 02:53:46 pm »
then clearcoat
Blazin
Blazin new trails!
Re: shaving.
September 29, 2011, 09:52:20 pm »
Sorry but you left yourself wide open for that one!
As far as the door handle holes you will ned to make a piece to weld into the hole. As far as the larger bolt holes a piece of brass stock works well for a backer while you slowly weld up the holes It absorbs the heat to reduce warpage of the sheet metal, plus gives something for the weld to sit on instead of just trying to fill up the empty hole.
1980c10
Re: shaving.
September 29, 2011, 09:55:28 pm »
You could also fill your stake pockets while you are at it.
Body, Glass & Paint
shaving.
