Performance
carb???
Topic: carb??? (Read 5465 times)
84chvy
carb???
October 02, 2011, 10:22:25 pm »
so i just got me a edelbrock permormer intake and now i need a carb. i have heard holley 600, edelbrock 600, and just use the quadrajet. what do yall think? its a stock app;ication with the only aftermarket is true duals with glasspacks.
1980c10
Re: carb???
October 02, 2011, 10:45:23 pm »
Any of the three can be made to run properly when set up right. I prefer holley due to there simple design. A lot of people will choose a q-jet becuase they believe they will get better fuel mileage due to the spreadbore design. IMO a properly tuned carb and driven vehicle will see the best fuel economy. I know how to set up a holley carb to preform the way I want it to and it has a simple easy to understand and effective design that allows you to easily make adjustments.
If what you have on your truck now is working-why not just keep using it?
cheeba_c10
Re: carb???
October 03, 2011, 10:15:54 am »
i actually had to get another carb. there was a holley 600 on the truck when i got it, but it wasn't working properly...you could adjust with only 1 screw (the one on the passenger side of the motor...the driver's side did nothing). the truck also ran like crap. my mechanic suggested going with an edelbrock. he told me that the holley's are very finicky when it comes to tuning. so we ended up at auto zone and i got the edlebrock 600 (performer series i believe). got it on and set up and now the engine runs great. i've had the truck since early august and i'm just now able to drive it. i had a holley on my 355 that was in my s10...600 i believe it was. that carb wasn't bad. i guess it's all on personal preference...
always live life following the 6 P's:
Proper Planning Prevents Piss Poor Performance
1980 C10 Bonanza
ohio hab
1984 C-10, 383 SBC
Re: carb???
October 04, 2011, 06:56:08 pm »
I also like Holley's, very simple to work on and adjust, also with electric choke
Psycho71
Re: carb???
October 30, 2011, 02:31:40 pm »
Carbs are like a lot of things. It depends a lot on what different people are used to running, and familiar with.
I like Holley myself. I can tune them to do what I want.
Any carb that boasts, "bolt on and go" will likely leave HP on the table. I want to be able to tune mine and make use of the other components I build into my engine. So I buy a Holley every time. Myt latest build was a mild 350 for my 4x4 burb. I slapped a 670 street avenger on it and had to do very little tuning to make it work well.
Others will say that Edle's and q-jets are just as adjustable. And I don't doubt it. I am familiar with holley so that's what I use.
Jason S
Re: carb???
November 05, 2011, 10:18:12 pm »
What carburetor did you choose?
84chvy
Re: carb???
November 06, 2011, 09:30:11 pm »
it still has the stock quadrajet as of right now. when i install my edelberock performer intake ill problably just use the quadrajet. it runs too good to mess with it.
Performance
carb???
