Author Topic: Features missing after upgrade.  (Read 9758 times)
« on: October 04, 2011, 02:49:19 am »
If you find/see something missing let me know.
1)gallery is gone right now
2)hover text preview is gone right now.
« Last Edit: October 04, 2011, 10:37:31 pm by Captkaos »
Re: Features missing after upgrade.
« Reply #1 on: October 04, 2011, 04:39:50 am »
smileys? and how bout when under you name it says how many post not its just a number? search button is there just no name on it.
and key stats is missing newest member.
beside your name on the top of the form it just has numbers for the inbox
« Last Edit: October 04, 2011, 04:41:23 am by Irish_Alley »
« Reply #2 on: October 04, 2011, 11:00:48 am »
There should be more smileys....
Mine says posts: XXXX  under my avatar,  is that is what you are talking about?
Wait, did you change your default theme?
« Reply #3 on: October 04, 2011, 01:12:14 pm »
I just added Facebook integration to the site.  You can now associate your ID with your facebook account if you have one....
Just go to Profiles and then Account Settings -> Facebook to associate it.
There are also new button for like and send for post.  Not exactly sure what the send does yet, but....
« Reply #4 on: October 04, 2011, 08:41:42 pm »
Why is the text so small?
Pictures get the right side cut off?
No little box to let you know other members are on?
Still no spell check?
Offline Da67goatman
  • Burban
« Reply #5 on: October 04, 2011, 10:06:13 pm »
I was just looking at my stats page under profile and couldn't read some of the text, white on white.  Might only be an issue in the Remix view. Also when posting some of the text is white on white.
<Pitcrew>
« Reply #6 on: October 04, 2011, 10:37:20 pm »
If anyone one is using any of the other Themes, they are going to be pulled soon, so if you see problems and you aren't using the default, I can't help you.  The other ones are leftovers that are not supported.
Post of the cut off pics Blazin?
What little box letting you know members are on?  On the main page it show the current users?
They supposedly fixed the spell check but I don't see it...
« Reply #7 on: October 05, 2011, 12:06:44 am »
yeah im using a non default theme. will there be other themes soon?
« Reply #8 on: October 05, 2011, 12:50:33 am »
found it a little tricky to select another theme. the drop down table wouldnt line up right so i had to click on the account tab. then after the screen loaded use the tab button to select look and layout. just a fyi for other is they have a problem
« Reply #9 on: October 05, 2011, 05:18:32 pm »
Dont use any themes other than default.  All the other ones are OLD and don't work with the new version...
I haven't had a chance to delete them yet.
« Reply #10 on: October 05, 2011, 05:29:10 pm »
The box is there tonight. Little green square dot by the username is what I was talking about.
Pictures are all there now!!!!
« Reply #11 on: November 01, 2011, 05:01:18 pm »
Spell Check is back.. FINALLY.
I also removed all themes except default.  Looking for another one, so if you seen one you like let me know.
« Reply #12 on: November 07, 2011, 11:05:08 pm »
Hover Preview text is working again, but ONLY in the Default theme  -CURVE
« Reply #13 on: November 28, 2011, 01:44:39 am »
is there a way to get rid of this "go up" "go down" next to the page selection lol i keep thinking it next page only to have it go up or down
