Author Topic: Fuses  (Read 7036 times)
Offline cheeba_c10
Fuses
« on: October 06, 2011, 09:30:53 am »
i've got an 80 c10.  i drove it the sunday nite and the headlights worked just fine.  i went to drive it 2 nites ago and the headlights didn't work.  the parking lights worked but the headlights didn't.  is there a fuse for the headlights??  any help is greatly appreciated!!
always live life following the 6 P's:
Proper Planning Prevents Piss Poor Performance
1980 C10 Bonanza
Re: Fuses
« Reply #1 on: October 06, 2011, 10:08:17 am »
could be the headlight switch or dimmer switch. did you try to switch from high to low beams?
Offline bigchevyc30
  • the pig
Re: Fuses
« Reply #2 on: October 06, 2011, 10:23:18 am »
hey i had that same issue for you it might be the headlight or dimmer but if its not check the wire going from the starter to the alternator i had my parking lights working but my head lights wouldnt work found out the wire from the starter to alternator had touched my header and burnt in half
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline cheeba_c10
Re: Fuses
« Reply #3 on: October 06, 2011, 12:37:15 pm »
so the first thing i checked was the dimmer switch...turned it all the way left and right and nothing.  turned the lights on and off a few times and nothing.  i'm new to this truck and am still trying to figure it out.  i assumed that the hi beam is like on newer vehicles...where its a pull back/push forward on the turn signal switch...but that's not it.  then i went to see if there were 3 positions on the actual headlight switch...like parking lights, then headlights, then high beam...but no haps.  i'll take a look at the wire from the starter to the alternator and see if that's it.
1980 C10 Bonanza
Offline bigchevyc30
  • the pig
Re: Fuses
« Reply #4 on: October 06, 2011, 12:56:02 pm »
you do know the igh low beam is a button on the floor up past the e-brake
Offline cheeba_c10
Re: Fuses
« Reply #5 on: October 06, 2011, 01:17:27 pm »
had absolutely no clue that was the high beam...lol!!  learn something new everyday!!  thanks big!!
1980 C10 Bonanza
Offline cheeba_c10
Re: Fuses
« Reply #6 on: October 12, 2011, 04:35:34 pm »
so it seems as there is a short or something.  sometimes the lights turn on and sometimes not. but i've really noticed that if the radio is on...the lights don't come on...headlights that is.  is the radio and headlight fuse one in the same?  any ideas??
1980 C10 Bonanza
Re: Fuses
« Reply #7 on: October 12, 2011, 11:21:15 pm »
the radio and lights arnt connected anyway sound like a connection or switch problem, lets say if the lows dont work and you switch to highs. will they work? or the other way around?
Offline cheeba_c10
Re: Fuses
« Reply #8 on: October 13, 2011, 01:46:38 pm »
so i was driving the truck over the weekend and i pulled up behind a lady at the light.  i say to myself..."let me see if these work"...cause i know i'll be able to see the reflection.  and low and behold...they worked.  i didn't want to flick my lights so i just turned them off.  i got home to check and nothing.  i've always got parking lights...just no headlights
1980 C10 Bonanza
