Author Topic: AC Compressor - Serpentine to V-belt  (Read 6778 times)
Offline Edahall
« on: October 07, 2011, 12:08:32 pm »
I've got a serpentine type AC compressor from a 1999 Tahoe that I would like to convert to V-Belt.  How can I do this?
For those who are wondering, I'm taking the 6.2L diesel out of my Suburban and putting it into the 1999 Tahoe.  Yes, I know that it would be best to find a serpentine setup from a 6.5L diesel 1996 and newer but those are far and few between.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Re: AC Compressor - Serpentine to V-belt
« Reply #1 on: October 12, 2011, 04:07:59 pm »
I don't think there is a option to use other engine pulleys other than the 6.5L.  I looked for this same info as I wanted to add AC to my CUCV 6.2L.
You could always mock up some brackets with some pulleys, but....
Offline wallew
« Reply #2 on: November 17, 2011, 08:49:14 am »
OK, yes they do make the compressor with either a serpentine OR a Vbelt.
The brackets ARE available.  You just need to know who sells them.  I'm unsure what I can and cannot post as far as who sells this stuff.  If you need that info, drop me a line.
Also, I own several CUCV's and one 1991 GMC Suburban.  Only the Sub has A/C because I don't want to mod mine.
But if you want, it HAS been done - guy called Devilman96 did a TON of stuff to his M1009 CUCV
here's the link over on Steel Soldiers - http://www.steelsoldiers.com/cucv/27571-cucv-build-here-we-go-again.html
« Reply #3 on: November 17, 2011, 01:23:50 pm »
There is only one place you cannot mention, and they have letters in their name..
Offline wallew
« Reply #4 on: November 17, 2011, 04:30:53 pm »
OK, then try Vintage Air.  They USED to have one that fit a diesel with two alt's.
Haven't checked lately.
