nv4500 conversion?
Topic: nv4500 conversion? (Read 20088 times)
kdime
nv4500 conversion?
October 10, 2011, 07:07:26 pm »
i only have three hwy gears and its eating up my fuel regardless of old man shifting/driving. at BEST i get maybe 14mpg @40-45mph. i know the 4.11 gears in frnt and rear dont help but i just want to get a tranny with 5gears (maybe 6? (nv5600?)) has anyone already done this? need help on cost and time spent (im doin this myself if i go that route)
life sucks sometimes... you just have to take it in stride
Re: nv4500 conversion?
October 10, 2011, 07:50:22 pm »
http://www.rhinoman.com/nv4500%20conversion.htm
kdime
October 10, 2011, 08:28:22 pm »
thanks i wasnt planning on spending that much though.. still in high school
bake74
October 11, 2011, 10:39:24 pm »
There are some people on here that have done the swap, have you used the search and looked through the threads on here ?
74 k10, 77k10 Tom
kdime
October 15, 2011, 10:56:32 am »
i did but not thuroghly. not in a big hurry to do it just a future plan. i like to plan a head if you know what i mean..
zieg85
October 15, 2011, 11:05:41 am »
If you are getting 14 now, that upgrade may get you to 17 if you are lucky. Our trucks are not known for their aerodynamics. Unless you have a lot of disposable income you will probably spend more than you will ever recoup. You may be better off going numerically lower in gears to get the RPM's down. My $.02
kdime
October 16, 2011, 02:33:53 pm »
if and when iget to it im changing gears to 3.73 if not 3.42 (if i dont add a lift). that along with a .75 with o/d tranny gear is (i'm hoping) will get a lil more than 17... aerodynamics
? did GM even know what those were in 83? lol
FritzA
October 16, 2011, 07:09:50 pm »
I'm in the middle of doing it. My truck is a 77 C20 and had the SM465. I wanted that OD for the highway too.
I found a 93-95 GM model with the 10 spline shaft for $500. I got the Advanced Adapters bellhousing for $370. New clutch $180. Crossover U-joint $30.
Now all I need is to get the driveshaft shortened.
I kept the old non-hydraulic linkage. If you allready have hydraulic you can use a GM bellhousing and be $$ ahead.
Good luck, BTW, it is one heavy transmission!!!!
Jason S
October 18, 2011, 10:11:35 pm »
Thinking out loud through a keyboard (and probably shouldn't be)...
For a lot less than the cost of the transmission swap and gear swap you can put a propane system on your truck and save money on fuel with less engine wear and no cold start engine stumble to boot...
Last Edit: October 18, 2011, 11:04:06 pm by Jason S
slammed79
Thou shalt not drive stock
October 19, 2011, 10:03:10 am »
One thing I've wondered about with this swap, is do you need to go to the 12" Clutch? And are the SM465's 10 Spine? I can't remember from when I had mine out last year.
Praise the lowered
October 19, 2011, 08:40:39 pm »
pre 85 sm465 are 10 while post 85 are 32. i dont know about the clutch but i would want it to match up as best as possible
slammed79
October 20, 2011, 11:33:53 pm »
I ask cause my clutch is only about a year and a half old, and the truck barely saw any miles till I rolled my Yukon last year. Even now it doesn't see much. It'd be sweet if I can get the adaptor and trans and just throw it in there.
Praise the lowered
nv4500 conversion?
