Author Topic: RPM  (Read 12276 times)
Offline 305chevy c-10
Re: RPM
« Reply #15 on: October 31, 2011, 06:25:19 pm »
well i already have screw in studs and guide plate with hardened rods ,1.5 rollers .550 lift  springs
Heartbeat of America yesterday's cheverolet
18T5C10
Re: RPM
« Reply #16 on: October 31, 2011, 10:07:57 pm »
on the 2 bolt thing, I along with several people have found that 2 bolts are stronger than 4 bolts, if you want ultimate strength (overkill for a street vehicle) get a 2 bolt and add splayed 4 bolt caps.  I wouldn't think twice about a 2 bolt.
Offline westsidek20
Re: RPM
« Reply #17 on: November 02, 2011, 02:38:21 pm »
Ive read that the camshaft's working range is the range that you get the most power, and anything under or over that still generates power but not as much.
So taking "305 Chevy" example of a 5500 range cam, is 5500 the redline or can he go over that?  ???
Re: RPM
« Reply #18 on: November 02, 2011, 04:09:28 pm »
going over the rpm range is over revving and if range ends at 5500, there is no point in spinning much over that.
Re: RPM
« Reply #19 on: November 02, 2011, 05:22:41 pm »
good info thanks ,i do have the bottom studded though
18T5C10
Re: RPM
« Reply #20 on: November 02, 2011, 06:11:54 pm »
Quote
Valves not closing (floating)
RPM does not = power. Operating in your peak power band is what you should be concerned with. An engine with a shorter stroke will rev more quickly and to a higher RPM than that of a longer stroke. Trying to make an engine that changes reciprocating motion into rotary motion and rotary motion into reciprocating motion there are going to be physical limitations for all of the factors mentioned in the previous posts. If you want an engine that turns high RPM build a rotary engine. I've never seen anyone build one and slap it in an old steel Chevy  ;D
