Author Topic: Turbo 350 to manual Swap help  (Read 7611 times)
Offline SeanK10
  • 79 K10
« on: October 17, 2011, 10:04:06 pm »
Hey guys,
         Ive got a 79 Chevy k10, Turbo 350 with what i believes the NP203,  ive Really been wantin to put a manual in this Badboy, Can anyone lead me to a Solid Manual trans and transfer case. im not sure what i should be looking for.    itll have a little stress, 35 in tires, stock gear ratio and Close to average hp and good torque. Any leand will help, Ill have pics up soon, i just started like 10 different prejects on the truck.
        Thanks Guys :D
79 K10:350, Th350 6in. Susp. 3in. Body 38.5 in. groundhawgs......I welcome Criticism
Re: Turbo 350 to manual Swap help
« Reply #1 on: October 17, 2011, 11:52:42 pm »
     The standard trans that came in the truck is a sm465, 4 speed with 1st gear being granny low.  Most people opt. to go with the nv4500 because of the 5 speed and overdive.
     There are several threads on here with those options, look in engine/drivetrain and search nv4500, or sm465.
Offline Engineer
« Reply #2 on: October 18, 2011, 06:00:38 am »
Pretty straight forward. Just find a donor truck from about the same year as yours, and swap everything out.
Everything interchanges pretty easily, especially if you find a similar year. If you have the whole donor truck you can get the tranny, t-case, shifters, clutch/brake pedal assembly, steering column, clutch linkage, and driveshafts.
You will have to fab at least one hole for the clutch linkage to go through the floorboard, but on those older trucks the floor board is dimpled where the holes need to be. Also depending on the donor, you can just swap out the center hump in the floorboard that already has the hole cut for the 4-speed shifter.
You should also already have the holes in the frame so that the clutch linkage is a simple bolt up deal as well.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline slammed79
  • Thou shalt not drive stock
« Reply #3 on: October 19, 2011, 08:34:41 am »
I'd look for an 85-87(91) truck with a stick, that'll net you hydraulic pedals as well. I don't think the 79 had the 203 factory, but I'm not 100% on that.
Praise the lowered
Offline SeanK10
  • 79 K10
« Reply #4 on: November 17, 2011, 01:10:02 pm »
Thanks Alot Guys, I Just lost my job so this projects gotta wait.  The truck has changed alot recently, not so much, Good changes i guess.  The driver side i busted out All the bondo and sanded the whole thing down to metal.  The front fenders Shot,and the bed was bad enough that i took lumber i had and built a Wood flatbed.  Im gonna start something on here with pictures of all ive done with the truck so far, so hopefully youguys'll see it
