Author Topic: hows this sound  (Read 8565 times)
Offline gsxrinthe9s
hows this sound
« on: October 20, 2011, 09:47:55 am »
I've asked around on this site and got some ideals
Current set-up 87 silveraldo 4 wd 305 / 350 turbo
I picked up a complete 96 LT1
there's a guy local that sells rebuilt trans for $700
Not sure what one to go with 700 r or ?
Not sure if the headers off the 305 will work
Assuming I will have to drop the gas tank and install a electric fuel pump
think I'm going to have to get a new bracket for the ac
Compressor am I forgeting anything ?
And of course all new belts hoses ect I'm thinking about useing
A air compressor bracket off same year vett I'm told they will allow
The compressor to clear the frame
Re: hows this sound
« Reply #1 on: October 20, 2011, 11:39:00 am »
the 4l60e and i think the 4l60 both require a computer to shift. the 700r4 doesnt so it would be the best bet if you want od
Offline gsxrinthe9s
Re: hows this sound
« Reply #2 on: October 20, 2011, 11:56:36 am »
I have the computer that came with the engine
If that's what your talking about ? .....I've done engine and trans swaps before
But that's always been with 60s muscle cars lol showing my age
Re: hows this sound
« Reply #3 on: October 20, 2011, 01:42:05 pm »
the computer for the 4l60 tells it when to shift. im not going to try to sound like i know what im talking about but if you can match up what trans came out of the truck and get wire harness then you should be ok
Offline gsxrinthe9s
Re: hows this sound
« Reply #4 on: October 20, 2011, 02:44:19 pm »
Well I have the wiring harness that connected the engine to the computer
Or is there another computer for the trans sorry if I sound lame
Re: hows this sound
« Reply #5 on: October 20, 2011, 05:05:10 pm »
The ECM from the LT1 will control the transmission, if you run anything other that it, you need a tuners help.
Offline gsxrinthe9s
Re: hows this sound
« Reply #6 on: October 20, 2011, 08:11:28 pm »
A BIG THANKS TO EVERYONE !!!!
I'm going to find out what granny was in the car and buy the same kind  hopefully it bolts to the transfer case....
Offline velojym
Re: hows this sound
« Reply #7 on: October 20, 2011, 09:01:34 pm »
When you find the right granny, make sure she can cook, willya?
Offline slammed79
  • Thou shalt not drive stock
Re: hows this sound
« Reply #8 on: October 20, 2011, 11:55:32 pm »
Doesn't the truck already have an electric pump? The 87 is TBI isn't it?
Praise the lowered
Offline gsxrinthe9s
Re: hows this sound
« Reply #9 on: October 21, 2011, 11:34:41 am »
Lol guess this Android phone decided granny was better than tranny
Offline gsxrinthe9s
Re: hows this sound
« Reply #10 on: October 21, 2011, 11:36:35 am »
@ slammed I'm not sure this pump will supply enough pressure
Re: hows this sound
« Reply #11 on: October 21, 2011, 12:00:54 pm »
you can't use the stock TBI pump, just switch to a Vette or F-body pump...
Offline velojym
Re: hows this sound
« Reply #12 on: October 23, 2011, 02:33:43 pm »
Mine's always doing that. Danged autocorrect
