Author Topic: wheel lug studs  (Read 5555 times)
Offline BadKarma510
wheel lug studs
« on: February 19, 2006, 09:34:00 pm »
Anyone got some good advise on replacing wheel sutds? I snapped one today
Offline toplessblazer
stud replacement
« Reply #1 on: February 19, 2006, 09:25:00 pm »
I am guessing you have a 2wd. If it's a front stud then you need to take the brake caliper off and remove the rotor. If it's rear then remove the drum and pound out the broken stud and install the new one. There is enough room to where you do not have to remove the axel in order to install the stud. I would replace all the studs since you will have it tore down anyway. Also a good time to do a brake job if needed
Offline BadKarma510
stud replacement
« Reply #2 on: February 20, 2006, 07:52:00 am »
it is a 4 wheel drive
Offline BadKarma510
wheel studs
« Reply #3 on: February 20, 2006, 09:34:00 am »
Where would I pick these up at? Local parts staor or do I have to order?
studs
« Reply #4 on: February 20, 2006, 08:04:00 pm »
Most parts stores carry them or can get them.
