Author Topic: Horses  (Read 8730 times)
Offline Bitzer!
  • Smiles per gallon
Horses
« on: October 24, 2011, 09:43:52 am »
Hi Guys,
I'm sure I've seen this topic before but couldn't find it.
My 454 has been refreshed,honed, rings, shells etc even though it only had 85k on it.
But the question is- what bhp should it roughly be? I've read Wikiyawnalotpedia but not convinced by the info on there.
cheers
Andy
1979 GMC CrewCab  C20 1t
Offline 1980c10
Re: Horses
« Reply #1 on: October 24, 2011, 03:57:07 pm »
Roughly speaking you should probably be around 250 mostly stock but with a few add ons such as a cam, headers, better heads, better pistons it would not be hard to get to 400.
Offline Bitzer!
  • Smiles per gallon
Re: Horses
« Reply #2 on: October 25, 2011, 04:37:03 pm »
Cheers fella. I must've miss read somewhere!
Slightly gutted at the standard tbh, altho the cast headers have gone I think a mild cam may be in order!
Cheers
Re: Horses
« Reply #3 on: October 25, 2011, 08:46:31 pm »
you also should be looking at the tq of that motor thats where all the power is at
Offline big bear
Re: Horses
« Reply #4 on: October 25, 2011, 10:15:42 pm »
yup...454s are torque monsters
Offline Bitzer!
  • Smiles per gallon
Re: Horses
« Reply #5 on: October 26, 2011, 02:07:50 am »
Ok guys gimme torque numbers and a comparrison of say a medium sized family saloon?
Re: Horses
« Reply #6 on: October 26, 2011, 01:47:25 pm »
Stock about 350lb/ft.  But a cam will greatly open it up.
Offline roadrage41
Re: Horses
« Reply #7 on: October 27, 2011, 06:33:08 am »
roughly twice the amount of your average mondeo
Offline 1979C20
  • Kyle Taulton.
Re: Horses
« Reply #8 on: October 27, 2011, 11:40:37 pm »
Horsepower sells cars/motors. Torque wins races.
Offline Bitzer!
  • Smiles per gallon
Re: Horses
« Reply #9 on: October 29, 2011, 03:58:19 pm »
Cheers all, sounds like it should be "fair" already.
Engine internals I struggle with. I can do the basics with the bottom end, rings, shells etc but then I stutter!
Is it a case of old cam out, new cam in or is there lots more to it? Timing and things?
With the 4 branch tubular headers and a reasonable cam would I be nearer the 500 lb/ft?
Cheers from a bloke who struggles with these things! "I can mig it if it helps!"
Re: Horses
« Reply #10 on: October 29, 2011, 04:10:04 pm »
I am so impressed with my stock 85 C20 454 4 speed with my highway gear.  I drive it real easy and really have to watch it when the roads are wet because the tires break loose so easily.  I am out a little ways in the country so rural driving mostly 45-55 mph.  I am in 4th by 35 and if I hit the go pedal to much accelerating from there the tires brake loose with my 3.21 gearing and mine is bone stock 137K miles with all the pollution stuff still on it choking it down.  I couldn't imagine controlling 500 lb/ft but it may be fun to try...
Offline Bitzer!
  • Smiles per gallon
Re: Horses
« Reply #11 on: October 30, 2011, 04:11:21 pm »
Cheers for all the info, I'm good at making things look pretty and wires but it stops there.
I've no idea of rear gearing yet - is there a "usual" for the 14 bolt? ex USAF truck?
Re: Horses
« Reply #12 on: October 30, 2011, 07:44:49 pm »
al the 14s that i have opened are 4.10
Offline Bitzer!
  • Smiles per gallon
Re: Horses
« Reply #13 on: October 31, 2011, 03:26:18 pm »
Irish_Alley > excuse my ignorance, would a 4-1 be more suited to pulling or cruising at speed?
Re: Horses
« Reply #14 on: October 31, 2011, 03:50:53 pm »
pulling. it will take off like a bat out of heck with higher numbers but top out very fast
