The Highs (Raising/Lifts)
2wd lift kit
Topic: 2wd lift kit (Read 8731 times)
rockin_77
2wd lift kit
October 24, 2011, 10:38:56 pm »
So i found a 2wd lift kit for my truck but its for a c10 not a c20. It is a brand new fabtech 3 inc coil and balljoint spacer lift. Would the coil lift my truck at all?
Last Edit: October 26, 2011, 12:17:27 pm by Captkaos
bake74
Re: 2wd lift kit
October 25, 2011, 10:43:59 am »
I would contact fabtech and ask them since they made it, who knows maybe it will work.
74 k10, 77k10 Tom
Isaac3384
2wd lift kit
October 25, 2011, 03:28:01 pm »
It should, depending on what motor you have, and what motor it was for. If it was for a half ton truck that had a small block, and yours has a big block. Also, go to a parts house and take a look at the ball joints for a c10 and a c20. As long as the mounting holes are the same, it should work just fine. You could even go on auto zones website and look up the balljoints for each truck; if the number is the same for both, you'll be just fine. I would bet that you're going to have to compare them, though. As long as the bolt pattern is the same, and the ball joint will mount up on the spacer, you shouldn't have any problems. Take the spacer with you when you go, and explain what you're trying to do.
Or, go on Fabtech's website, look up the parts breakdown, and see what is different; if anything.
Good luck with it!
Last Edit: October 26, 2011, 12:18:30 pm by Captkaos
1979C20
Kyle Taulton.
Re: 2wd lift kit
October 26, 2011, 11:58:41 am »
Fabtech doesnt list these lifts anymore the last time I checked.
Isaac3384
2wd lift kit
October 26, 2011, 01:05:20 pm »
In that case, I would do the other option I listed...look up the ball joints and compare them. Compare the springs, and if it all looks like it will bolt up the same, go for it. As long as you don't have a big block, and that lift was for a small block, you should be ok...
rockin_77
Re: 2wd lift kit
October 26, 2011, 08:16:35 pm »
Ok I will do that. My truck has a small block in it.
Isaac3384
2wd lift kit
October 26, 2011, 09:34:42 pm »
I did a little research for you; the balljoints are not the same part number, but the springs are. I believe the only thing you'll need to do is go to an auto parts store and compare the balljoints. They should have the same bolt pattern, which means your spacers should work.
rockin_77
Re: 2wd lift kit
October 27, 2011, 03:56:40 pm »
They have the same bolt patter but the ball joint spacer has a smaller hole for the 1/2 ton ball joints.
Last Edit: October 28, 2011, 04:03:55 pm by Captkaos
Isaac3384
2wd lift kit
October 27, 2011, 03:58:13 pm »
Either that, or see if it can be machined out if you really want to use it...
rockin_77
Re: 2wd lift kit
October 27, 2011, 08:12:26 pm »
Ill post some pics in a bit. If it was machined out it there wouldn't be enough material left over
2wd lift kit
